Help: need help removing rear tail light pieces on an 03 accord sedan,help
hi evryone i need help removing the corner tail lights on an 03 honda accord sedan.the rears on a sedan are 4 pieces 2 in the center and 2 on the sides.i removed the centers and now i tried to remove the corner tails took out the 3 bolts on the inside of the trunk and it still wont pop off.are their anymore bolts im not noticing??please help experts.thanxxx
MalleusMaleficarum
I will not help someone install Altezzas.
I won them on an ebay auction for 1.00 all that was missing was one of the screws that pops it into place.so i basically got brand new altezzas for a $1.00 so if once i put them on they dont look better than the red/clear stock ones.then i will switch but it dont hurt to see for $1
not exactly sure if there are anymore, but did yo upull back the carpeting and check if there was another one?
yes i did pull back the carpet,thats the only way you can get to the first 3 bolts for the corner tails.i removed the 3 and then they're still tough to pop out,i need to know if those are the only bolts to remove
