Wheel Bearing Help??
HELLO EVERYONE THIS IS MY 1ST POST!!! can some one tell me how to change my front driver wheel bearing?? i need this done ASAP!! it has play in the steering wheel and makes crazy noises driving Thanks
the steering wheel has a little play from left to right sitting still. driving when you let the wheel go it always pulls to the left. i do have a camber kit and just got it aligned a month ago. at the shop my car was lifted you can rock my left front wheel up and down. it makes the wheel tremble and a raa raa raa raa sound that speeds up with the car.
To check and see if the tie rods and tie rod ends are bad you need to jack the car up first and then on one side at a time grab the wheel firmly and see if you can wiggel it back and forth to see if there is any play in the wheel at the same time pay attention to the tie rod and tie rod end to see if either one of them move if they move then then they are bad. Even though you dont have power steering the rack can still be bad.
my axle on the driver side broke sat. i guess b/c old age i sure dont have the power to break it lol but we put in an axle from my friends 93 hatch and when we tightened up the axle nut the tighter it got the more the wheel would would not turn!! is this normal?? im guessing it had something to do with the bearing being bad?????????? help
ok i haven't got neither of these replaced yet and this is my daily driver until i get the new short block for my 91 eclipse GSX :drool: (which will hopefully be by the end of this month, i cant wait finally something with some speed) what kind of risk am i at right now?? My pregnant wife rides with me in this car but i wont let her drive it b/c of this problem. what might happen if this bearing\hub gets any worse it has been doing this since about Jan. i just never had the $$$ to fix it. How much will the hub be if i need it? how will i know if i need it??
