Help, my check engine light is on
Old Sep 22, 2002 | 09:16 PM
CBR900RR's Avatar
CBR900RR
Default Help, my check engine light is on
I already did take off both the battery terminal and touch it together for 1 min, restart the car and the light still on.
I heard that if you switch gasoline brand, the lights will comes on, I was using Tesoro 92 gas for the last 6 yrs, and on the last 2 fill up, I use Chevron 92 oct, will that be the cause??
Is there a terminal below the glove box that I can connect to see the problem code?
I have a 96 2.5 TL
Thanks
Old Sep 22, 2002 | 10:48 PM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
You'll have to bring it back to the dealer to see what the code is. Switching gas brand WILL NOT cause the check engine light to come on.
Old Sep 23, 2002 | 12:07 AM
CBR900RR's Avatar
CBR900RR
Thanks for the reply, I just find out it is code 65, any idea what this is.
Old Sep 23, 2002 | 09:31 AM
AcuraTL's Avatar
AcuraTL
You'll need the service manual in order to find out what the code means.
Old Sep 26, 2002 | 02:35 PM
DTK's Avatar
DTK
May I ask why you touched the terminals together. In addtion the codes should have a prefex PO . Anything after 96 is OBDII
Old Sep 27, 2002 | 06:29 AM
CBR900RR's Avatar
CBR900RR
I touch the terminal together to get the code, and what is OBDII and PREFEX PO?
Old Sep 27, 2002 | 02:26 PM
DTK's Avatar
DTK
Touching the terminals together will not get you a code. OBDII stand for On Board Diagnostics 2. How did you come up with code 65 ? P is always the prefex in OBDII. I can check the service manual for you if you like. but I need the correct code.
The data connector is not under the dash. This connector is located in front of the shifter under the coin tray. You pull the little cover out. You won't get the codes with out a reader. In addition the code will not go away if you disconnect the battery. Hard code lights will stay on even if the problem goes away for at least 3 run ins.
Old Sep 27, 2002 | 03:43 PM
CBR900RR's Avatar
CBR900RR
Thanks for the reply, I had already take it to Acura and they fix it under the extended 140,000 mi warranty, they said something like the secondary O2 sensor.
Can you check for me the code for the O2 sensor, thanks.
Old Sep 27, 2002 | 03:45 PM
DTK's Avatar
DTK
The secondary O2 sensor is the one after the cat. This is a sampling sensor to make sure the catalytic process is working. I will get you the exact code tomorrow.
Nelson
Other Honda & Acura News
Jul 25, 2008 03:10 AM
DaMaN
Accord
9
Sep 26, 2005 04:11 AM
bboygraphix
92+ Civic/EL & Del Sol
11
Apr 29, 2003 05:31 AM
epoxy
Prelude
8
Nov 15, 2002 04:14 PM
REbornHONDAneer
Accord
9
Aug 18, 2002 04:22 PM
