check engine light / atts light
Old Nov 10, 2002 | 01:26 PM
epoxy's Avatar
epoxy
Regulator
Default check engine light / atts light
my 'check engine light' and 'ATTS' light are on in my 5th gen prelude...
what should i do? my friend redlined it when he dropped into a lower gear, but it was only for a breif second. the light came on like 3 minutes after it happened. i just wanted to hit 'em :madfawk:
but... everything sounds fine and the car runs just like it did before.
should i not drive it until i get it checked out or what?
any help would be VERY appreciated.
Old Nov 11, 2002 | 09:48 PM
prelude1897's Avatar
prelude1897
Don't freak out. Just see what code you're throwing and you can find your problem there. Try reseting your computer by taking off your negative battery wire for awhile, then put back on and start your car. If the light doesn't come back on, then you're car is fine.
Old Nov 12, 2002 | 06:52 AM
epoxy's Avatar
epoxy
Regulator
alrighty... thanks.
i'll be back when i find out what code it's throw'n
Old Nov 14, 2002 | 12:22 PM
epoxy's Avatar
epoxy
Regulator
well..i did that trick, and it went off for a day, then it randomly came on when i was driving. about to read up on how to find out the code, but i'll be back when i do.
thanks.
Old Nov 14, 2002 | 02:33 PM
epoxy's Avatar
epoxy
Regulator
heh..help me
Old Nov 14, 2002 | 02:47 PM
prelude1897
Go to http://www.hondaprelude.to/main_checkengine.html
Old Nov 14, 2002 | 04:19 PM
epoxy's Avatar
epoxy
Regulator
PERFECT!
Old Nov 15, 2002 | 12:26 PM
epoxy's Avatar
epoxy
Regulator
alrighty... got a code 1.
code = Primary Heated Oxygen Circuit
Detection Item:
High/Low Signal
Probable cause:
Open or short in Primary HO2S sensor
Primary HO2S sensor
ECM
that's what some website said. any thing i need to know? should i keep driving my car?
Old Nov 15, 2002 | 04:14 PM
prelude1897
You can still drive your car. You just need to either get a new O2 sensor, or check your wireing on your catalic convertor or your header
