Washed engine compartment = Check Engine light
Old Sep 25, 2005 | 03:03 PM
DaMaN's Avatar
DaMaN
Default Washed engine compartment = Check Engine light
Hello n00b here . Check Engine light is now on after 24hrs after I washed the engine compartment. What did I do wrong?
Old Sep 25, 2005 | 03:12 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
Welsome to HAN. Take your car to Autozone and get a code. There is a FAQ section in the forums where you can check the problem with a code. Autozone will tell you the code for free.
Most probaby its some sensor that got wet and its seding an error to the ECU but we dont know which one.
Old Sep 25, 2005 | 03:18 PM
DaMaN's Avatar
DaMaN
Thanks for the quick response, Do you think I screwed it up or I can salvage the sensor?
Old Sep 25, 2005 | 03:44 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
You can unplug the battery and connect it back to get rid of the Check Engine Light but its always a good Idea to get it checked cause it might be something major or could be nothing plus its free.
Make sure you have the Radio code if you unplug the battery.
Get us the code and then we will tell you whats wrong. Also put your car information with it.
Old Sep 25, 2005 | 06:17 PM
skabone69's Avatar
skabone69
or you could pull the fuse for your ecu(the clock fuse) and you don't have to worry about your radio code. and then if the code comes back on you can read it yourself.
http://www.filtsai.com/accord/engine_codes/index.php
Old Sep 25, 2005 | 09:05 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Why are you posting links to another website when I've already posted every single DTC there is and how to find it out here?
daman: read the FAQ.
Old Sep 25, 2005 | 09:38 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
Yeah all the codes are here in the FAQ section, thanks to 98coupeV6(Chris if Iam right?). Just get the code and check it. If you dont understand the code or how to fix it then ask us.
Old Sep 25, 2005 | 09:44 PM
98CoupeV6's Avatar
98CoupeV6
Yup Chris I helped the guy you referred to me in email BTW.
Old Sep 25, 2005 | 11:07 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
thanks, It all about helping each other :cheers:
Old Sep 26, 2005 | 04:11 AM
skabone69's Avatar
skabone69
opps, sorry I keep forgetting about that. my b. :slap:
