Simple AMP Question
Old Jul 8, 2002 | 06:24 PM
mphurley's Avatar
mphurley
Default Simple AMP Question
Just got a simple general question about amps... Do they just improve bass or will they improve the overall sound?? I'm not putting in subs, just going to use it on the 6x9 speakers in my car. Is it worth it?? Any advice is helpful
Old Jul 8, 2002 | 07:08 PM
96sedanR's Avatar
96sedanR
at higher volumes, ure spkrs will sound much clearer with an amp then without. most amps also have some sort of crossover so you can put more bass to ure spkrs. im also planning on amping my 6x9s later on...
Old Jul 8, 2002 | 07:11 PM
b00gers's Avatar
b00gers
if anything put an amp to the front speakers...they are most important...
yes by using an amp you are giving the speakers more and cleaner power. using an amp also gives you the chance to finer tune the sounds by adjusting the gain and freq cut off..
Old Jul 8, 2002 | 07:24 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
any speakers amped will sound better at all volumes, given they are in fine working condition. The more power you can give a speaker (up to its max capability of course) the better it will sound. Even better if you have an amp with a crossover that way you can give your speakers more power they can use effectively by eliminating the frequencies that cause distortion, thus improving the sound quality.
Old Jul 9, 2002 | 07:54 AM
SiClone's Avatar
SiClone
X-Moder8er
Hopefully, you are considering adding an amp to power aftermarket speakers and not the stock ones...
Old Jul 9, 2002 | 12:22 PM
III 4U2NV III's Avatar
III 4U2NV III
Yeah, rear deck speakers are mainly for rear fill which you can pretty much get away with running them off of the headunit. Run as much power to your front stage as possible.
Old Jul 9, 2002 | 09:58 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
hahaa, i ran 300 watts to my OEMs in my s10, never blew em either.
Old Jul 9, 2002 | 11:26 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
my friend has a Tahoe w/stock speakers that sound damn good. Is it a Chevy thing?
tvon
Accord
22
Nov 8, 2004 06:15 AM
ManInCamo
Jul 29, 2004 02:52 PM
reech-around
Mar 10, 2004 11:32 AM
