speaker terminal for custom box
Old May 1, 2003 | 07:22 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
you want to run 0 gauge wires from the amp to the subs.... thats overkill... 10 gauge is overkill... 16 or 14 gauge is fine.
you may want 0 gauge for power though.
Old May 1, 2003 | 08:02 PM
epoxy's Avatar
epoxy
Regulator
ah, ok. thanks for clearing that up.
Old May 1, 2003 | 08:08 PM
Randy12vp's Avatar
Randy12vp
Skip the terminal all together.
Old May 1, 2003 | 08:27 PM
epoxy's Avatar
epoxy
Regulator
think that's what i'm going to do. What should i seal the hole with?
Old May 1, 2003 | 08:32 PM
Randy12vp's Avatar
Randy12vp
Silicone
Old May 2, 2003 | 01:06 AM
rcurley55's Avatar
rcurley55
Originally posted by epoxy
and...it's not over kill.
read https://www.honda-acura.net/forums/s...threadid=66187 for more info on my system.
I sincerely hope that you understood that discussion was about your power wire from the battery and not your speaker wire.
Even 8 ga is overkill - most people run 12 when all they really need is 16.
Remember, the shorter the run, the smaller the wire can be.
