speaker terminal for custom box
Old Apr 30, 2003 | 08:44 PM
epoxy's Avatar
epoxy
Regulator
Default speaker terminal for custom box
can anyone recommend a good speaker terminal to handle ~1000 + watts? I wasnt sure if any terminal will do (say...one from radio shack) or if i have to get an special one.
Old Apr 30, 2003 | 10:38 PM
b00gers's Avatar
b00gers
get the ones that you have to twist...not the spring loaded ones. i think those are crap.
you can always skip the terminals on the box. drill a hole for the speaker wire to go through, then seal up the hole afterwards. but there are convience drawbacks.
Old Apr 30, 2003 | 10:54 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
www.parts-express.com
Old Apr 30, 2003 | 11:48 PM
LjN_728's Avatar
LjN_728
Radio Shack
Old May 1, 2003 | 05:46 PM
epoxy's Avatar
epoxy
Regulator
hmm...i'm doing my system with 0 guage wire.... can anyone recommend a site or something, because i havent found anyone to make one that big yet
Old May 1, 2003 | 05:49 PM
epoxy's Avatar
epoxy
Regulator
or hell, would it just be easier to run a hole through the box with the wire? kinda wanted a terminal, but I can manage.
Old May 1, 2003 | 06:21 PM
LjN_728's Avatar
LjN_728
Is a 0 guage necessary for what you'll be running? That is a pretty heavy load if you need that kind of guage. Hopes to find a connector that will accept 0 guage is slim to none. I was going to tell you that u could use a twin banana connector, but that's out of a question. Well if u really need to use 0 guage, you could always fabricate something.
Old May 1, 2003 | 07:12 PM
SumAccordGuy94
Older Honda Fanatic
0 gauge for speaker wirring????????!!!!!!!!! umm, can you say OVERKILL!!??
Old May 1, 2003 | 07:16 PM
epoxy's Avatar
epoxy
Regulator
sub wiring.
Old May 1, 2003 | 07:17 PM
epoxy's Avatar
epoxy
Regulator
and...it's not over kill.
read https://www.honda-acura.net/forums/s...threadid=66187 for more info on my system.
