Sub wiring
What is the best wiring for 2 10 inch JL subs with a 500w kenwood amp? What wires do I need for the amp. Here are pics of the setup I got, I am not sure what model jl's they are b/c I got them by trading someone Rockband for Ps3:
those are the JL w0 series and are rated for roughly 250w rms PER Sub and they are single 4ohm coils.
if your amp can support 2 ohms, wire them parallel to get the most out of your amp. Also, the box looks a little big for those subs. Those subs need large cubic feets but when you place it into a bandpass box, you loose alot - they require sealed enclosures for maximum performance.
sealed enclosures is when it holds all the air inside and allows nothing out. the current box is alright, not the greatest box, but it works. using the sstock deck is no problem. tha box is a little big for the rsx.
In laymans terms, a sealed enclosure is a box with no holes in it. You have a bandpass box (the waves from the front of the sub is channeled through a port).
Theres hardly a way to tell if that box is "good enough." You have it already, so just hook it up and see if you like it. You can use your stock radio, but you will need to feed the amp the signals through the rear speaker wires via a line output converter. That will get rid of the need of RCA cables to the deck.
Im just gonna stick with the stock headunit right now. I am trying to save up for a D3. Circuit city is installing the stuff tomorrow. The guy said I didn't need an RCA converter, He said that they had some wires that he could splice into something so I wouldn't have to buy the converter. He says if I get an aftermarket headunit he would have to rewire something and would charge $180 to do it since it is a bose system so it would be better to stick with the stock headunit if I plan on upgrading to a D3. He also said if I want to upgrade my components that I would have to get a aftermarket 4 channel amp, Is that true? All he said I needed was the 4 gauge wiring kit and the RCA cables.
