need more batt power
Old Jan 13, 2007 | 02:13 PM
  #31
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Originally Posted by akeura369
i was joking around chill out..and to answer your question because that sub will hit harder and deeper than any other sub its size
Fail. A Cerwin Vega Stroker Pro will lay a hurting on that sub.
Old Jan 13, 2007 | 08:31 PM
  #32
dleccord's Avatar
dleccord
pwnt.
Old Jan 13, 2007 | 11:53 PM
  #33
97teg's Avatar
97teg
Out of curiosity what is the sd of that sub? Is the 40mm xmax linear one way or total?
Old Jan 14, 2007 | 04:35 PM
  #34
totalimmortal
MalleusMaleficarum
Knowing Cerwin Vega, it will most likely be linear one way. I believe xmax is defined as linear one way excursion.
Old Jan 16, 2007 | 07:46 PM
  #35
rcurley55's Avatar
rcurley55
guys, try to stay on topic please....
Old Jan 17, 2007 | 02:11 PM
  #36
nicholas_nsx's Avatar
nicholas_nsx
Banned
Why not just get a seperate battery to run the amp off?
Old Jan 19, 2007 | 07:57 AM
  #37
totalimmortal
MalleusMaleficarum
Because......then that battery has to be tied into the vehicles charging system which will just add more drain to the system since the alternator now has two batteries to keep charged
Any other ideas??h:
Old Jan 20, 2007 | 11:50 AM
  #38
Tyler88's Avatar
Tyler88
sinking steps rising eyes
Any other ideas??h:
smaller system.....or a new alternator
if you want to power something that big you should expect to get another alternator...
Old Jan 21, 2007 | 07:39 PM
  #39
totalimmortal
MalleusMaleficarum
:werd:
