hooking up an extra LED
Old Sep 23, 2002 | 11:05 AM
steveng's Avatar
steveng
Default hooking up an extra LED
how can i do it? can i solder it to the wire of existing LED?
Old Sep 23, 2002 | 11:27 AM
b00gers's Avatar
b00gers
if you are adding just one...go for it.
Old Sep 23, 2002 | 12:52 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
just make sure if you connect before the resistor, to add a resistor of proper value for the new LED.
Old Sep 23, 2002 | 01:54 PM
08SnakeEyes08's Avatar
08SnakeEyes08
Vince Tran....
d/c ur battery incase........ i didn't and i had to buy a new relay for my car
Old Oct 2, 2002 | 08:53 PM
OneToughCivic's Avatar
OneToughCivic
why? you did something wrong then.
Old Oct 4, 2002 | 06:21 AM
INlude's Avatar
INlude
yeah, you shouldn't have to disconnect your battery just to wire in an LED.
Old Oct 4, 2002 | 07:02 AM
Bass Mechanic's Avatar
Bass Mechanic
Default Re: hooking up an extra LED
if you do that 2 things will happen.
the original LED will not be as bright.
the load resistor for that led may become overloaded.
you really need to add a new load resistor for the LED your adding. also you need to make sure that the LED driver circut is capable of driving 2 LED's
TriniSpeed
4
Jun 16, 2003 07:55 AM
New93Civ
92+ Civic/EL & Del Sol
4
Apr 6, 2003 10:14 AM
brak
9
Mar 1, 2003 12:18 PM
mwz26
Accord
8
Nov 14, 2002 12:01 AM
alexman
4
Oct 13, 2002 06:59 PM
