hooking more than 1 lcd
Old Jan 14, 2003 | 07:12 AM
TriniSpeed's Avatar
TriniSpeed
Default hooking more than 1 lcd
Is it necessary to have a video amplifier (http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3000655854)
to hook up more than one lcd?
Or can i just buy a fre y spliters and split off each video and audio jack?
Old Jan 14, 2003 | 11:48 AM
xivera's Avatar
xivera
insert witty remark here
You could try going about the process (splitting & what-not) w/o using a video amplifier but, that depends on quite a few things. (cable distance from video/audio source, input/output variables, etc.) If you feel you need a better signal going to the other LCD's, then you can pick up a video amplifier.
What exactly are you trying to do!?
Old Jan 14, 2003 | 04:12 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
yeah, like he said... it depends... if you're only running 2 monitors, a simple "Y" splitter should be fine... anything more than that should have an amp/splitter.
Old Jan 14, 2003 | 05:47 PM
TriniSpeed's Avatar
TriniSpeed
I am planning on running 3 tvs. I am trying to split only the video into 3 different videos. what will happen if I dont use a video amp?
Old Jun 16, 2003 | 07:55 AM
KVZ_Productions's Avatar
KVZ_Productions
quality will be degraded slightly. may have noise/interfiernce in the signal and if your video source (dvd player/ps2/xbox) has low power video output it will be affected more than a source with a higher voltage output. id just recomend getting the amplifier you can usually pull off 2 displays without one but for 3 id recomend it you can find them on ebay cheap (30-60 dollars) better to put it in while you got everything apart then do it and realize you need the amplifier.
-good luck
-krazymatt
