Hooking up Tach. Where to put green wire
Old Apr 5, 2003 | 08:45 PM
New93Civ's Avatar
New93Civ
Default Hooking up Tach. Where to put green wire
WHere do I put the green wire. Its for the tach to show the RPMs. Its says to put it where the - terminal is on the coil is that it
Old Apr 5, 2003 | 09:11 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
Much easier solution. If you look on the passnager side wiring harness by the top of the shock tower, on the in-car side of the harness there is a one wire plug (usually a blue/silver wire, or something of the like). It's usually covered in a little rubber boot and taped to the top of the harness. This is a factory tach test lead (for hooking up a tach in the engine bay to check idle and such). You can just clip that wire and run the green wire to that and you've got your signal. Good luck. Seeya.
Old Apr 5, 2003 | 09:29 PM
New93Civ's Avatar
New93Civ
thanks. but there is like 20 wires there Blue or silver
Old Apr 5, 2003 | 10:08 PM
Andy's Avatar
Andy
Default What's up?
It's not a wire in the main harness, it's seperate from the rest and terminates in a single wire plug before the in-car/engine harness plug. If you can't find it, I have a pic but it's on a computer that shut down for the night. I'll post it tomorrow if you can't find it. Seeya.
Old Apr 6, 2003 | 10:14 AM
nogarobluecivic's Avatar
nogarobluecivic
B20 EH3
it is a blue single wire, driver side, at the firewall, with a plastic plug on the end. cut and splice.
