hooking up p/w and locks
Old Feb 28, 2003 | 05:17 PM
brak's Avatar
brak
37 ?!
Default hooking up p/w and locks
anyone know a good DIY for hooking up power windows and locks to a fully manual civic ?
i got the stuff from a junked 99-00EX, and want to wire it into my 98DX.
Old Feb 28, 2003 | 05:41 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Maybe one of the manuals (I'd say haynes, but apparently I'm the only person on the civic board with one h: ) can help in doing this. I'm sure the dx is prewired, you just need to find where to plug it into.
Old Feb 28, 2003 | 05:55 PM
brak's Avatar
brak
37 ?!
i got a haynes too
im hoping it's just plug and play
Old Feb 28, 2003 | 06:31 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
i'm sorrie to inform you, but the DX's are NOT prewired for the door locks and power windows. I ended up getting the harness off of the EX model, strip the unnecessary wires and tapped into the ignition.
Without changing out the entire harness underneath the dash, it's very time consuming and difficult to have it all plug n' play.
like others sed, get a factory manual for wire coloring.. GOOD LUCK!!!:thumbup:
Old Feb 28, 2003 | 06:35 PM
brak's Avatar
brak
37 ?!
i have all the wiring and everything that was in the doors, i gotta tap those wires to the dash ones ?
Old Feb 28, 2003 | 06:49 PM
SUPER LAUBO
KiMBO's Hubby
are you talking about the stock ones inside your DX doors rite now? if so, i believe there are only two wires for your speakers.
if you are talking about the wiring off of an EX then that's a different story. the wiring should consist of about 10 wires in a single harness. this harness is separated into three segments that connects with a single plug in between each door.
the first segment = left driver door (i'm talking about a two door here)
the second segment = extends from the inside of the dash, loops underneath the back of the front seats, up around to the right side of the car and stops at the quarter panel.
the third segment = right driver door.
if you only have the wiring and the female plug for the doors, then you are missing the main harness that connects the two.
if you need help, just holla GOOD LUCK!!!
Old Feb 28, 2003 | 07:07 PM
brak's Avatar
brak
37 ?!
after reading ur segment stuff...
i have the first and third wire segments, nothing between though.
i have a feeling this is gonna be a hell of a project
Old Mar 1, 2003 | 10:01 AM
19.3secS2K's Avatar
19.3secS2K
but your elbows will thank you in the end, as will you when you can finally get keyless entry
Old Mar 1, 2003 | 11:29 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If you decide to do an aftermarket kit, check out 4thgenhatch in the 4th gen section. He's got a how to on his site.
Old Mar 1, 2003 | 12:18 PM
SUPER LAUBO
KiMBO's Hubby
naww, it's not too bad. just go to a junk yard to get the segment in between. that will make everything alot easier. :thumbup:
