Audio, Security, & Automotive LightingTroubleshoot wiring problems and get equipment suggestions all in one place. Now expanded to include Automotive Lighting
ok yea, cause the warn just turns the siren on for a few sec rather than the alarm wire that turns the siren on all the time, so i tap the warning wire into the alarm where should i put it?
no, that should be already taken care of. I'd suggest wiring the rest of the car, and attach the 2 green wires to each other, (completing the circuit) and test it. That spot is a place to put an early warning device such as a cell phone caller or something like that i believe.
ok so the green wire is extra, not having it hooked up wont make the siren warn function not work, ok i get it. thanks for all the help. i am going to try and install the 6 wires of the main harness @6pm est
i cant with that cause at the plug there is a small green wire that loops from the green's port to the blue port. i would have to tap that green wire into something if anything
