Installing Viper 671XV in 92 civic
99 CG3 Owner
yea i took off a very bad crimestopper, that any caviler or eclipse could enable or disable, and it didnt have a shock sensor.i will try and hid the wires as best as i can. thanks for all the help
Originally Posted by XScarAudio
most important thing, is make sure your ignition kill/starter kill splices are well hidden too..if not, the car is actually easier to steal
Also, on Viper alarms (and all DEI products) the starter disable circuit is normally closed - that means that if the thief disables power to the alarm, the starter circuit is automatically re-engaged.
Do yourself a favor and install a hidden ignition or fuel pump cut switch somewhere else. That in combination with the alarm will stop most thieves from getting your car.
Any experienced thief + enough time to work in peace = your car is stolen.
///o\\\///o\\\
i def. agree. with all of that. in general though, w/ civics etc, there are 3 in every lot, so a well installed alarm might make them move to the next. ALso, a good, loud siren, and making sure your car is either parked smart, or close enough to hear helps a lot.
Even so, an alarm won't prevent damage to the car....which is sad.
99 CG3 Owner
i have a problem, the install went good except 2 things, my shock sensor only goes off if you hit the sensor itself, is it in the wrong spot?
and my status led doesnt stop blinking when i turn my alarm off. while i am driving it blinks 2 times, waits 3 seconds and repeats
Please help
Please help
Please help
Please help
