Installing Viper 671XV in 92 civic
99 CG3 Owner
anyone know how to wire this in to my civic? i dont know where to locate the wires to tap into them,the ones i need are....
parking light wire
domelight
(-) door switch
(+) door switch
trunk wire( so when the hatch opens it goes off.... like the wire that goes to the light in the cluster that tells u its open
_____________________
i have the starter wire allready done from a previous install
i have the negative put in
i have the ground on
i got the hood pin
key switch i got
siren an obvious
trunk release not a option
___________________________
when you hook the relay up to the starter wires the relay has a extra yellow wire coming out of it. is it a ground?
___________________
also where should i mount the shock sensor and antenna?
parking light wire
domelight
(-) door switch
(+) door switch
i got the hood pin
key switch i got
siren an obvious
___________________
///o\\\///o\\\
Check behind your stock radio and see if you have the stock alarm wiring harness. I tapped into all wires there, with the exception of the Parking Lights...i never bothered with those for some reason...oh well.
Mount the shock sensor on the floor board/tranny tunnel, and i mounted my antenna inside the glove box area (when the glove box is removed, there is metal under it)
99 CG3 Owner
when you installed the shock sensor there is a extra green wire coming out of the sensor that is labeled for warning, then at the plug there is a green wire that loops onto the blue, where do i splice or tap the green wire into? the blue one?
99 CG3 Owner
i did and it wasn't clear or i didnt understand. it has a plug but the plug that goes into the brain has a blue red and ??black?? wire and the spot for the green there is a small green wire that loops from its spot into the blues and then at the shock sensor there is all the wires going to the plug plus a green wire that is free that is labeled for the warning alarm
///o\\\///o\\\
i'll be honest...i know wiring very well, and it was a pain in the ass trying to figure out my alarm installation. they make it that way so that only trained techs do it. I did MUCH searching on the web for tips on my specific alarm, since they change up the wires all the time. Finding the wires in the car should be easy....just search the web and you'll find descriptions. thats how i found a real-world diagram of mine.
Good luck
Good luck
99 CG3 Owner
i found nothing for the 671VX, searching everywhere, i just dont know which wire on the 4 plug harness to tap the warning wire for the shock sensor
Good luck
Good luck
