Making a sub box...specifications needed!
Originally Posted by A_D
and i'll bet you're convinced JL is the BEST car audio gear out there aren't you
Originally Posted by cooliojones
Wait, why you say that AFTER i bought my new 10w6v2 sub and 500/1 amp? What are some other recommendations? I've heard about Orion, but that's it. What else?
the shape of the box isn't of huge importance as long as its NOT a complete cube. the depth, height and widtch can't be the same length. you need to tend to stay away from this. i think it has to do with the sound waves bouncing off the back wall and since all the sides are the same, the wave bounces back at the same length it was produced, and that will create cancelation. i'm not quite sure
but you can pretty much make any dimensions you want (as long as the sub has enough mounting depth and width). TWO sides can be the same length if desired but all 3 can't.
And also, when calculating your box volume, don't forget to factor in wood thickness and sub displacement.
now children - play nice in the sandbox or else.....
TTT is correct, a perfect cube isn't that big of an issue when talking about sub bass.
you can also run a ported enclosure without a ssf if you want to. Just tune it low and use common sense...
