Aftermarket Speakers Blowing
Old Dec 23, 2003 | 08:51 AM
nfg05's Avatar
nfg05
clipping happens when you're underpowering the speakers and the amplifier chops off the top and bottom of the sound wave that's being sent to your speakers.
Old Dec 23, 2003 | 02:50 PM
dawrenn's Avatar
dawrenn
I learned a little bit from this place: http://www.eatel.net/~amptech/elecdisc/2ltlpwr.htm
Old Dec 24, 2003 | 11:03 AM
dawrenn's Avatar
dawrenn
Do you know anything about Low Pass Filter and High Pass Filter? I have my HPF set at 50Hz and and my LPF set at 80Hz +6. I know it is different on different head units but I want to know if having it at +6 will cause my speakers to blow?
Old Dec 24, 2003 | 06:42 PM
SpeddyDOHC's Avatar
SpeddyDOHC
Default Re: Aftermarket Speakers Blowing
Originally posted by dawrenn
I just want to know how many times if any has your aftermarket speakers blown? Do you know what could be causing the speakers to blow?
Kind of O.T. This is a question for anyone who has a sub or subs. What volume do you have it at when you are listening at a normal volume? and what volume when you have the sub pumping?
I listen to it at 14 for normal volume and when I want it to pump I turn it up to atleast 25.
Old Dec 25, 2003 | 08:10 AM
dawrenn's Avatar
dawrenn
Default Re: Re: Aftermarket Speakers Blowing
We don't care
Old Dec 27, 2003 | 02:37 PM
dawrenn's Avatar
dawrenn
On my head unit I have a setting that says select bass frequency. Does anybody know what that should be set at? There are 4 options 40-63-100-160 (Hz)
