CAI for hybrid?
Old Mar 3, 2003 | 06:58 AM
dantastic's Avatar
dantastic
cx power!
Originally posted by AccordSleeper
97+ lude cai is 3.0 inches and fits fine. the only thing that doesn't line up is the bracket, but their is a tight fit between the rubber connector and the hole in the wheel well that it's ok.
you can just use tin shears to enlarge the hole. you need to do that to the 97+ prelude too when installing the aem cai
Old Mar 3, 2003 | 07:11 AM
AccordSleeper's Avatar
AccordSleeper
Former H22 Accord Owner
no it doesn't need to be enlarged, it fits, the snugness keeps it from shaking. i don't think the 97+ludes can even fit the pipe in, w/o opening up the hole. i also cut a slice in the little rubber tubes from the stock intake system and lined the cut-out area where it hit the rubber connectors to make it tighter.
