CAI for hybrid?
Originally posted by Nightshade
Aluminum build and comes with a rechargeable filter (same build as K&N) and all hardware to mount it.
PM me for more details.
Nightshade----Clean out your box....
I am interested in one 2....
Thanks
ask accordsleeper about this before you do anything
im fairly sure he has the prelude intake on his accord. . .3" pipe
you might consider that especially if you dont already have an intake to put on it. . .
a friend of mine had one custom made... the accord piping was choking off some serious hp... and wouldn't that just defeat the purpose....
go custon... if too expensive then go prelude...
you can always try the cai ver2 from aem... bigger diameter...
PM box is cleaned out ...sorry about that guys.
As for the diameter difference well pick which one ya want because I can get them for any model Honda you want....even V6 if you have one
Originally posted by AcsRcool
that is accordsleepers bay from a pic taken nov 9th. . .lude CAI seemed to fit fine as i recall. . .
Hey, he even has a sway bar. I heard they dont fit with the H22.
Was told the strut bar hits the valve cover.
Damn, Guess I need to talk to you guys instead of most the people in the basement.
97+ lude cai is 3.0 inches and fits fine. the only thing that doesn't line up is the bracket, but their is a tight fit between the rubber connector and the hole in the wheel well that it's ok. you could also use a 92-96 lude cai which is 2.75 inch which should give better low end at the expense of top end. i would not suggest the use of an accord aem cai for a long period of time cause you are killing your topend. your better off using a 3 inch generic short ram than a 2.5 inch cai.
