turning brake rotors
Old Nov 7, 2005 | 03:37 PM
JDM ACCORD's Avatar
JDM ACCORD
Originally Posted by meangreen90
i've paid as low as $7.00 per rotor to get them turned. thats obviously pulling them off and taking them in yourself. $14-15 would be more respectable though. goodluck
I got mine turned for 13 dollars, I bet no one can beat that, but for sure don't pay more than 50 bucks
Old Nov 7, 2005 | 03:42 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
Originally Posted by mckeand13
I haven't changed rotors on my accord yet, but from the sounds of it, it's supposed to be pretty easy.
-Remove caliper
-Remove caliper mount
-Remove two screws holding rotor on
What am I missing?
What year is your Accord, the fifth gen had a press on rotor....not a DIY removal if you ask me.
Old Nov 7, 2005 | 04:47 PM
mckeand13's Avatar
mckeand13
Originally Posted by shonnv
Well its hard for people with no idea of what they are doing and dont have proper tools (like me) but if you have knowledge and tools, nothings is hard I guess
I didn't mean that to sound like a bash fest or anything. I'm just trying to figure out if I'm thinking it will be something other than what it really is.
Old Nov 7, 2005 | 04:49 PM
mckeand13's Avatar
mckeand13
It's an '02 so that makes it a 6th gen. I've read that there are two bolts that hold the rotor to the hub just to make it easy. Maybe it's a slip fit over the hub to center it and it gets rusted?
Just ordered my Brembo blanks from 88rotors today. Hopefully have them by the weekend so I can get 'em on.
Old Nov 7, 2005 | 04:55 PM
93EXaccord's Avatar
93EXaccord
Engines hate me!
no 4th gen had pressed on rotors, and the fact that i DIY'd it should mean i had the tools, and knowledge to complete the task. anything after a 93 is a job for anyone with a 110 pc tool set.
Old Nov 7, 2005 | 05:36 PM
JDM ACCORD's Avatar
JDM ACCORD
that is true, my dad used his set of tools that he bought from a tire shop going out of business. great deal on the tools by the way
Old Nov 7, 2005 | 06:37 PM
MrChad's Avatar
MrChad
My bad I thought the 5th gen had pressed on rotors, hence why there was the CL rotor mod for that gen to switch to the non-pressed on CL rotors. My mistake, I have a 6th gen and a TSX and luck out to have fairly normal non pressed on rotors hats.
Old Nov 7, 2005 | 08:03 PM
strykernyc's Avatar
strykernyc
mrchad u are right the 5th gen does have the front rotors pressed and is a btch to change them no matter what tool u have. and any shop will charge a min of $200 to change both front rotors (just for labor) 6th gen and up is a peace of cake to change them, just like the "rear" rotors of my 5th gen.
Old Nov 8, 2005 | 07:33 AM
01ACCORD's Avatar
01ACCORD
Piece of cake. Just did mine. Had all 4 rotors turned for $70. Only problem I ran into was the two set screws were rusted in. Even an impact screw driver would not remove them. I suggest before removing the caliper and such, you see if you can remove the screws. I drilled the heds off, and put new ones in. Pretty simple if you have the tools. I put anti-sieze on the new ones. But hey, they've been in there for 140k miles!
PS, if your pads are even close to needing replacement, do it now.
PSS, before you put those turned or new rotors on, wash them really good with dishwashing liquid. Then dry and don't touch! You don't want to get any oils on there. If they start rusting over nice and brown before you even get them on the car...that's a GOOD thing!
Old Nov 8, 2005 | 08:58 AM
93EXaccord's Avatar
93EXaccord
Engines hate me!
my mistake, i though only the 4th gen was the red-headed step child of honda, now i know when i buy a new one to make sure its at least a 6th. yeah for my screws on the back i just popped the head with a cutting torch, they are just to hold the rotor on during assembly of the vehicle. so if you don't replace them just use a lug nut to hold the rotor on untill you get your caliper on.
