Please help me Vibration problem
Old Sep 16, 2005 | 12:09 PM
yuoyuo827's Avatar
yuoyuo827
Default Please help me Vibration problem
Hi all
Please help me
My accord is vibrating when it is at 40-60 k/m only and the steering wheel its good no vibrating but the vibrating only in body also I check the wheels its good and I already change all tier. can you tell me What is wrong??
My car 2003 4cly Auto. wheel 18 with Eibach Springs Pro-Kit
That’s my car
Thank you
Old Sep 16, 2005 | 12:14 PM
sibiryk's Avatar
sibiryk
It's a rear wheel(s). Balance it.
Old Sep 16, 2005 | 12:36 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
Welcome to HAN. Most probably it is the rear wheel but its always good to balance all of them.
Your car is nice but you need a tint job and it will look nicer. I got the same wheels in 17".
Old Sep 16, 2005 | 03:18 PM
Accord1278's Avatar
Accord1278
If you do a search, this is a pretty common problem and you can find a lot of answers by reading the other post. My car recently had the same problem, about a week ago. First of all, make sure ALL your tires are properly balanced. Make sure they are torqued down to the right specs, I believe it's 70-80 ft/lbs for the Accords. Also, it could be that you need hubcentric rings, if you don't already have them. Lastly it could be that you have a bad tire and/or rim that might be bent. My car had a bad tire in the rear, which you could not tell from just looking at it from any angle. It wasn't until the tire was taken off the car for balancing that the problem was discovered, obviously in my case, balancing would have made absolutely no difference due to the fact that one of my tires was totally screwed up. Good luck.
Some info. that might help you out...
http://www.tirerack.com/wheels/tech/...jsp?techid=107
http://www.tirerack.com/images/tires/vibechart.pdf
http://www.tirerack.com/tires/tirete....jsp?techid=20
Old Sep 16, 2005 | 05:07 PM
blacknight07601's Avatar
blacknight07601
Remove all the wheels
Balance all of them
Remount them and torque to proper specs.
Hopefully, the people who remount them will know to tighten the lug nuts criss cross and don't go in a complete circle
