Changing brake fluid
Old Sep 7, 2002 | 08:44 PM
  #41
Illusion-Lighting's Avatar
Illusion-Lighting
Illusion Lighting
normally for something this critical i would have a shop do it, but since i'll be running calipers from a legend, the bleeding process is a little more complicated as the bleeding valve is on the bottom of the caliper now and not on the top.
Old Sep 8, 2002 | 02:53 PM
  #42
vtecinside's Avatar
vtecinside
Cracker Quack!
Originally posted by see_fu
I plan on flushing out all the old stuff, so should I completely flush it out and completely saturate the brake line w/ air and then pump in new fluid or should I pump in new fluid as the old stuff goes out?
you should add fluid as you go...then you have less bleeding to do.
ToxicByte
92+ Civic/EL & Del Sol
3
Jun 19, 2007 12:58 AM
VRGNCD5
Do It Yourself
17
Apr 12, 2005 05:11 PM
Dimi
5
Sep 29, 2003 02:33 PM
lucgirl79
26
Dec 11, 2002 07:26 AM
Spec R
3
Sep 6, 2002 05:53 AM
