ignition key hard to turn
Old Sep 24, 2004 | 05:43 PM
bunick's Avatar
bunick
Default ignition key hard to turn
When I either shut my 95 accord off or turn it on the ignition key catches and I have to work it back and forth and sometimes get a little aggressive with it to get it to turn. Is it in my ignition or someone tried telling me that it might be in my shifter not allowing it some how to release. Any body ever have something like this happen? Thanks!
Old Sep 25, 2004 | 10:51 AM
buster133's Avatar
buster133
Default key
I had a similar situation with the ignition key on my old 89 Accord. When it was cold out and if the car wasn't fully warmed up, the car would turn off, but the key wouldn't push in during the last turn to remove it, and other times the auto shift lever wouldn't move out of park without the manual override. It replaced the shift selector in the console that tells the lights on the dash what gear the car is in and I never had the problem again. If it's an auto, try moving the shift lever back and forth in the park position while removing the key.
Old Sep 26, 2004 | 11:35 AM
phoenixitc's Avatar
phoenixitc
I have a 95 Accord EX and had the same problem about a year ago. I had to have the ignition replaced, along with a new set of keys.
Old Sep 26, 2004 | 12:33 PM
bunick's Avatar
bunick
Thanks for the info. I have tried moving the shift lever back and forth with no luck. The way it feels it is going to be a new ingition. Thanks again!
Old Sep 26, 2004 | 12:48 PM
honda94vtec's Avatar
honda94vtec
Honda94VTEC
I had the same issue with my old 94 Accord , where you had to insert the key a bit partially out and turn the key, cause if you didn't it just wouldnt turn.
Old Sep 26, 2004 | 01:34 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
I'm pretty sure it can't hurt to lube it. Put a little oil on the key then insert it and remove it a couple of times, turn it etc.
I've had to do that with house locks, which evan though very different, require a little maintenance sometimes. Most things like this come greased from the factory, but after 10 years it needs to be serviced.
Old Sep 26, 2004 | 04:57 PM
Nors's Avatar
Nors
倍力恋
I have the same problem with my 95 accord ex v6... but only in the morning.. so I am pretty sure its the cold, cause afternoons it comes out fine (they tend to be alot warmer) but its been like this for a year... i just eventually get it out, sometimes it takes up to 5 minutes though. It makes me look like an ass.
Old Sep 26, 2004 | 05:15 PM
bluetwo's Avatar
bluetwo
I stick to my story!
Just dab a little 30 Wt on it. It can't make it turn any worse.
Old Sep 26, 2004 | 05:30 PM
GenXer's Avatar
GenXer
Registered Honda user
For lube on a lock I'd use graphite instead of a heavy oil.
Your key could be worn out. If you have two keys, try the other one to see if it acts the same way.
