daytime running lights
Old Jun 28, 2004 | 05:18 AM
blueboy84's Avatar
blueboy84
hm... still cant figure it out
Old Jun 28, 2004 | 07:26 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
Did you check those two fuses? What are you having trouble with right now?
Old Jun 28, 2004 | 10:21 AM
blueboy84's Avatar
blueboy84
yea.. i checked the fuses... the are okay. im having problems with my daytime running lights. Everything else works fine.. my headlights and all when i pull the switch, just that my daytime running lights dont come on
Old Jan 30, 2005 | 06:53 PM
rltuso's Avatar
rltuso
How did you make out blueboy? I am having the same problem with my 96 accord. Would love to know how to resolve it.
Old Jan 30, 2005 | 08:40 PM
oei28's Avatar
oei28
I never really got the point of daytime running lights. You'd think people would be able to see a car during the day pretty easily.
Old Jan 30, 2005 | 09:13 PM
strykernyc's Avatar
strykernyc
there is a time in the morning when DRL come in handy. DRL are good because they dont blind people and allow the incoming traffic to see you easy without blinding them. at dawn if u turn ur headlights on u will bother the incoming traffic.
Old Feb 1, 2005 | 05:48 PM
rltuso's Avatar
rltuso
Default DRL Message Resolved
I had the same problem with my 1996 Accord (DTRL Message, and right high beam not working). Answer to the problem is the DRL Relay which is located just above the brake pedal. It's a four inch by one and a half inch grey box. Disconnect the connector, then slide the box up to remove it. It says DRL Relay on the box. Open it up, and re-solder the connections. Worked well for me. Seems over time the solder joints fail. To buy a new one I hear is approx $130+.
