check engine light
Old Apr 12, 2004 | 05:20 PM
curryspeed1's Avatar
curryspeed1
Default check engine light
my check engine light just came on in my 6th gen manual sedan. what should i do? what could it be. i have a fresh oil change and i used mid-grade gas for the first time and took about a 300 mile drive this weekend... any suggestions?
Old Apr 12, 2004 | 06:23 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
check the engine :slap:
Seriously though have you checked the oil level?
Old Apr 12, 2004 | 06:43 PM
2kAccord's Avatar
2kAccord
#010597
Tighten the gas cap, reset the light, see if it comes on again.
Old Apr 13, 2004 | 04:14 AM
curryspeed1
how to reset the "check engine light" i know how to reset the service engine soon light.
Old Apr 13, 2004 | 05:35 AM
skabone69's Avatar
skabone69
pull fuse #13 on the passanger side fuse panel. its a 7.5 amp fuse for the clock. it won't affect your radio so you don't have to worry about using the stock radio code.
Old Apr 13, 2004 | 06:42 AM
JimBlake's Avatar
JimBlake
Or you can go to AutoZone & have them read the error code, before you erase it...
Old Apr 13, 2004 | 07:07 AM
skabone69's Avatar
skabone69
or you can use a paper clip and look up the code yourself
Old Apr 13, 2004 | 01:59 PM
slade311's Avatar
slade311
milk-n-cookies
to reset it the easy way just unhook ur negative battery terminal for like 5 minutes. and then put it back on. after a max of about 30 miles if it doesnt come on, ur cool. how many miles does it have on it. the cel comes on when the car hits a certain amount of miles (i think 60k) so u will take it to the honda place.
Old Apr 14, 2004 | 07:02 PM
skabone69's Avatar
skabone69
only problem with that is if you have a stock radio, you'll have to enter in the code after you reconnect the battery. besides, wait 5minutes, or just pull the fuse which takes a couple seconds.
Old Apr 14, 2004 | 08:05 PM
accordvtec77's Avatar
accordvtec77
the CEL is NOT programmed to come on after a certain amount of miles. It's only purpose is to come on if there is a malfunction in the vehicles emission control system. It's OBDII, not an odometer. Otherwise ALL makes of cars would be doing the same.
