Shite starter might be going out
Old Mar 31, 2004 | 07:24 PM
axemansean's Avatar
axemansean
Default Shite starter might be going out
Took a while to turn over and start tonight after I got off work. Its either that or the battery is low because of a short somewhere. I know its not the battery dying because the battery is less than a year old. Guess I'll find out in the morning.
Old Mar 31, 2004 | 07:31 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
autozone can check your battery and charging system for free... that can help troubleshoot the problem. If there is a problem with the alternator or somewhere else in the charging system, it will not keep the battery fully charged, making the car hard to start.
Old Mar 31, 2004 | 08:11 PM
axemansean's Avatar
axemansean
Its my job for the AM tomorrow. Hoping it was just the fact that it was because it was unusually cold tonight.
Old Mar 31, 2004 | 08:14 PM
SmutWanter's Avatar
SmutWanter
"Made to Please"
If the car is turning over then it probably is not the battery nor the alternator, because the battery is getting the power to crank and eventually turn over. Problems like this could be any of a group of items that is causing your car to be sluggish turning over. Could be low on oil, you could need a new fuel pump, fuel filter, spark plugs, etc... Fortunately if it is any of these that is causing it, then they are simple and inexpensive solutions.
Old Mar 31, 2004 | 08:18 PM
SmutWanter's Avatar
SmutWanter
"Made to Please"
Unuaslly cold, below freezing?... Then another possibility is if your gas tank was not full is that sometimes condesation can form in your gas tank ---> fuel pump and if it was below freezing causing the condensation to freeze and clog your pump from getting the proper fuel needed to start it right away. If this problem only happend just this time then it is a possibility. Heet makes an additive that you can pour into your gas tank to solve that problem if you think that is the case.
crxb16er
CRX & Pre 92 Civic
17
May 3, 2003 07:35 AM
Hondaman
92+ Civic/EL & Del Sol
4
Apr 29, 2003 03:43 PM
Zedron
Engine Swaps, Tech & Tuning
3
Mar 28, 2003 11:04 PM
Macster33
13
Oct 13, 2002 04:41 PM
Macster33
Accord
6
Oct 10, 2002 06:59 PM
