Another SRS Problem
Old Jan 25, 2004 | 03:32 PM
Rockey's Avatar
Rockey
Default Another SRS Problem
(2000 Accord LX Sedan)
My SRS light came on after pulling the SRS fuse. I've now learned my lesson. The SRS light is now on.
I have tried the paperclip method of jumping the brown and black wires on the 16-pin Data Link Connector.
I jumped the wires.
I turned on the ignition on and the SRS light stayed on for 6 seconds, then went off.
I disconnected the paperclip within the 4 seconds time frame.
The light came back on as anticipated.
I reconnected the paperclip within 4 seconds - but the light never went off again.
Any advise?
Autozone??
Thanks - Matt
Old Jan 25, 2004 | 06:25 PM
Lager's Avatar
Lager
ACK !!! Quit THAT !! They were talking about the MES connector attached to the fuse box,, at least I hope they were,, I gotta go look back now..
Old Jan 25, 2004 | 06:31 PM
Lager's Avatar
Lager
Ok,, they have thewrong connector,, the one you want is colored Gray,,ALWAYS GRAY,, not like them instructions in the post below,,2 yellow wires !!,, No exceptions !! Reset procedure as correct per below submission..Darn this intenet,, Some dealer tech just lost out on a LOT of money....
Old Jan 25, 2004 | 08:41 PM
Rockey's Avatar
Rockey
I'm confused...
Is the Service Connector Location different than a MES connector in a 2000.
There was no yellow bundle/wires neer the fuse locations - only behind the steering column.
Please see the link below for pics and text to see where I went wrong.
http://alflash.narod.ru/honda.htm
Thanks
Old Jan 28, 2004 | 02:13 AM
BigTicket's Avatar
BigTicket
I did this procedure sometime last year and I have a 2002 Accord SE and mine was yellow, not gray. Maybe it's different in a 2000 but I'm pretty sure that the same gen accord would have the same wiring but don't quote me on that.
Rocky, the pics in the link you provided are for a 5th gen (maybe, looks like a lot of diff gens on that page) so yours will look a little different. The plug is located on the drivers side right under the steering wheel. My accord has two yellow plugs there and the correct one to do the reset procedure on is the smaller of the two plugs (it's not wrapped in that yellow wire wrapping though). The plug looks just like the one in the pics from this site
http://www.hondapitstop.com/accord/t...1/SRS/srs.html
but, again, that accord is a 5th gen so your plug will be plugged into something (fuse box maybe) and not have a plug cover on it. I hope this helps. When I did mine there was a website that has reset instructions for a 6th gen with pics and everything. It made doing my reset very easy but I can't find it anymore. If I do find it I'll post the link here.
Old Feb 1, 2004 | 05:44 PM
Rockey's Avatar
Rockey
Thanks- problem solved using this trick.
Matt
SJTrance
Accord
13
Jan 31, 2004 07:56 AM
white lightnin
92+ Civic/EL & Del Sol
9
Dec 17, 2002 11:36 AM
MokeyJ
Accord
6
Nov 10, 2002 03:59 PM
TheRapture
4
Sep 17, 2002 07:59 PM
kevinlau
Accord
7
Sep 17, 2002 11:37 AM
