Installing Head Unit
Old Jul 24, 2002 | 09:04 AM
AccordSE's Avatar
AccordSE
Default Installing Head Unit
I just got a Pioneer Head Unit for my 97 Accord...Is the only thing I need to get to install it the wiring harness? Thank you for your info...
Old Jul 24, 2002 | 09:08 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
pretty much, you can use the stock rear bracket to hold the deck in place, then I use a metal strap (homemade) wrapped around the deck and screw it into the holes on the pocket below... then just place it back in how it came out. When you do this, make sure the depth is the same as the stock setup, this may require the fabrication of a nifty little bracket for the back. There are also dash kits available for your car, but they tend to not look so good... they look really cheap and tacky.
Old Jul 24, 2002 | 09:58 AM
grandmarkie's Avatar
grandmarkie
sodering(sp?) iron, soder, shrink wrap and you should be set. I custom made a bracket in the back for mine. it's an L shaped piece of metal, pretty easy to make. Good luck!
Co0lDood
11
Dec 1, 2004 10:28 AM
BASSboy1284
Do It Yourself
9
Jul 27, 2004 07:46 AM
94civicEX
11
Feb 26, 2004 08:47 AM
94civicEX
3
Feb 25, 2004 11:01 AM
AccordManiac
5
Jul 5, 2003 03:50 AM
