New SOHC turbo setup for me YEAH!
Old Oct 8, 2003 | 10:27 AM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Originally posted by Jkan2001
no one in dallas is available to tune hondata right now, also i don't have enough money to convert to obd2 and get s200
What are you talking about? You ever hear of tony the hondata master.
Old Oct 8, 2003 | 10:29 AM
crucial Si's Avatar
crucial Si
Banned
should of let me know about the SFP manifold, i get a hook up there...i think :thinking:
Old Oct 8, 2003 | 03:08 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Default Re: Re: New SOHC turbo setup for me YEAH!
Originally posted by Jafro
SlowBoyRacing has a TIAL 38mm wastegate for $210...
http://www.slowboyracing.com/Wastega...35mm/35mm.html
I see that the tubular manifold is heat treated, and that it has a 3 year warranty, but I guarantee it won't last as long as a cast part will. Tubular exhaust manifolds have a lot of problems, especially on daily drivers. The welds fall apart over time because of all the heat-cycling, and the weight hanging off of them. You won't ever have to worry about that with a cast part. Tubular parts are great for drag and show cars, but you probably shouldn't waste your money buying tubular manifolds for a daily driver unless you don't mind replacing them often. Thank Buddah for that warranty...
Having a wastegate on one runner isn't so bad. As long as the pressure before the turbo is relieved, it doesn't make much difference where it comes from, it will properly do its job. The post-turbo flow is what you want to be concerned the most with because that's going to have the largest affect on your spool time... and you'll need that more than anything if you go with that big of a compressor cartridge.
Still, I really do like the manifold pictured on the bottom. What's up with the flange angle on that one? It looks like it would point your turbo inlet towards the bell housing, and I don't know why that would be good. Is there a pic of one of these installed anywhere? Possibly with the T04E cover?
goto www.jdmuniverse.com and look at the ride of the month it has the SFP manifold installed on an ITR motor i think with a t3/t04E turbo (possibly precision but i forget)
cast manifolds are also prone to cracking and problems and don't spool up as well as tubular. My friend's turbo LS had a problem spooling and when he took the manifold off he discovered a crack in the back but with a 3 yr warranty i'm willing to at least give the SFP one a shot.
and TXhatch, i know tony tunes but he's over @ bob norwood now, i heard he may do some side jobs in a while but at the moment he's not available?
Old Oct 8, 2003 | 03:23 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
nice... :goodjob: what are your expected ET's??
also, u still running stock internals besides a new head gasket?
Old Oct 8, 2003 | 03:30 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
yeah stock internals, i haven't put in the head gasket yet but once i get the turbo stuff on i'm going to pull the head and do a 2mm thicker headgasket, arp headstuds and a blockguard.
If i can make 250 whp i'm hoping for some low low 13's maybe high 12's on slicks or drag radials. My current 175/173 whp setup is good for 13.2 if you convert it from my 8.52 1/8 mile time.
Old Oct 8, 2003 | 03:40 PM
incublinkus's Avatar
incublinkus
JDM Fan Boy
yeah, I don't think they make too many cast stainless manifolds for d-series...cast iron sucks. I think its a pretty good choice on the SFP, not that I am experienced or anything, but its what I would get, based on what i've read elsewhere...
Old Oct 8, 2003 | 04:30 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
pretty snazzy :thumbup: I like the manifold... Good luck, I hope she holds up
Old Oct 8, 2003 | 04:43 PM
SRT_Andy's Avatar
SRT_Andy
..... is good for 13.2 if you convert it from my 8.52 1/8 mile time.
Nah, you would have messed it up somehow....:naughty:
Old Oct 8, 2003 | 05:08 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
yah with my luck 3rd gear would've taken a dump and i'd drive the car home with 4 gears. :fawk:
