New SOHC turbo setup for me YEAH!
Originally posted by Jkan2001
actually that guy held 16.5 psi for quite some time and then he got greedy and upped to to 20 psi when he warped his head. He actually killed it from hydrolock and the internals kinda blew to chunks.
I think 12 psi would be easily attainable with a 8.8:1 CR and good tuning.
h:
i'm hunting for a TiaL 38mm wastegate
http://www.slowboyracing.com/Wastega...35mm/35mm.html
Also get a South Florida Performance 1010 heat treated tubular steel mani and downpipe. Here are some pics of it, i like it a lot more than the cast iron drag/fmax/revhard mani's and the wastegate positioning is much better (it distributes evenly instead of being on just 1 runner) AND it has a 3 yr warranty
Having a wastegate on one runner isn't so bad. As long as the pressure before the turbo is relieved, it doesn't make much difference where it comes from, it will properly do its job. The post-turbo flow is what you want to be concerned the most with because that's going to have the largest affect on your spool time... and you'll need that more than anything if you go with that big of a compressor cartridge.
Still, I really do like the manifold pictured on the bottom. What's up with the flange angle on that one? It looks like it would point your turbo inlet towards the bell housing, and I don't know why that would be good. Is there a pic of one of these installed anywhere? Possibly with the T04E cover?
