when to let off the clutch
Old Sep 21, 2003 | 09:20 AM
vtecadil's Avatar
vtecadil
Default when to let off the clutch
alright well im new to driving a stick and id just like to know to about what rpms do u revv ur car upto before u go in 1st from a stop, im somewhere between 1,200-2,100 rpms and its got kind of a jerky movement and not really smooth, do u think im revving it up to high when moving some people seem to say i am but im not sure.
Old Sep 21, 2003 | 11:03 AM
niko's Avatar
niko
Im driving a f_cking egg
Old Sep 21, 2003 | 11:11 AM
Civic Type Sev's Avatar
Civic Type Sev
:rofl:...... funny one niko. :slap:
Unless you want to smoke your tires I'd say you've got it about right. (1200 to 2000) Just practice releasing the clutch as smooth as you can. With a little bit of practice you'll get smoother and smoother.
When you start wanting to take off faster (e.g. drag racing) you can raise the rpm's a little higher but don't dump the clutch. Try to ease off of the clutch to control tire spin. It takes practice but it's worth it.
Good luck
Old Sep 21, 2003 | 11:33 AM
Dimi's Avatar
Dimi
Indeed, 1200-2000 is just about right. If you're car is all jerky like you say it is, you're not releasing the clutch smoothly. It's ok, everyone goes through this process when they start driving manual, don't feel bad. See it as finesse. Press the accelerator pedal slowly WHILE release the clutch slowly aswell. Hondas clutches grab pretty high so you can start to release the clutch like a second before you start to press the accelerator pedal. It's like one movement. At the same times you press the accelerator pedal you're also releasing the clutch. You can feel when it grabs enough to let go of the clutch completely. Usually, under normal driving conditions (not 7700rpm drops, heh), you're going to hold the clutch like 2 inches from it being completely released for a sec. or 2 to completely engage the power stransfer without getting that jerky feeling. You'll get used it, trust me. Becomes 2nd nature. Just practice practice practice. Remember, one solid motion from both feet at the same time. It's going to come o the point where you can shift all 5 gears without the vehicle even having a jerky feeling, as smooth as driving an automatic. Have fun! :thumbup:
Old Sep 21, 2003 | 11:38 AM
b_dyche's Avatar
b_dyche
owned by a 9 car pile-up
<1000 RPMS if you're really good...
serioiusly, though, around 1200-1500 works well for smooth starts. Also find the "grab point" or "stall point" on your clutch so you can let off to that point before you even touch the gas, and just gently apply gas & release clutch, and voila! The car will go smooth and gentle...
Old Sep 21, 2003 | 12:50 PM
Dimi's Avatar
Dimi
Making the car move up to speed, WITHOUT pressing the accelerator pedal, only clutch...like I do. :fawk:
Old Sep 21, 2003 | 06:04 PM
vtecadil's Avatar
vtecadil
well im gettin better and thanks for the input, eh my g/f thinks its funny when i drive.
Old Sep 21, 2003 | 06:20 PM
onebadassdx's Avatar
onebadassdx
give yourself a couple weeks, after that, it'll become second nature to you, you won't even be looking at your tach
Old Sep 21, 2003 | 06:49 PM
Mx6GT91's Avatar
Mx6GT91
or taking off in 2nd, which is kinda bad for you clutch.
Take it to about 1200-1500rpm and let the clutch out slowly so that you know when it engauges. When the rpms slowly fall (should be slowly or your not doing it right) keep the clutch pedal there and give it slightly more gas and fully let the clutch out (match the gas and the clutch pedals). My cousins learning also, she just got a 94 Interga LS
