Has anyone had problems with this bolt?
Old Sep 18, 2003 | 07:13 AM
alllooksnnogo's Avatar
alllooksnnogo
Just another import lover
exactly what slacker said dude. Torch the sucka We had to remove the bolt in order to put on my suspension. It took us quite a while to remove them and torching it was the only way.
Old Sep 18, 2003 | 08:42 AM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
torch that sucker!!!! flame and heat is your best friend when it comes to this kind of situation. :thumbup: good luck!!!
also try to apply pressure from the other side of the bolt while using an impact driver, this might get the thread started..
Old Sep 18, 2003 | 08:57 AM
fish's Avatar
fish
i just removed my lca and strut together and then just cut off the stut since i was replacing that at the same time then just had a new bushing pushed in and called it a day
Old Sep 18, 2003 | 04:20 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I had to burn that fukker out with a torch, sawzall and punch when I did my shocks. Broke 3 goddam impact sockets. Good luck :nervous:
Old Sep 18, 2003 | 04:37 PM
huviduc's Avatar
huviduc
ive done three fifth gens, and they are always siezed, ive jsut had to break them all and cut the shit out and heat it up. just do what ever you cna to get it out, and buy new ones. you MOST likely will not get out with out breaking them
Old Sep 18, 2003 | 06:46 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
I hate those bolts, they don't seize in the threads that often, most likely it's rusted inside the metal bushing on the LCA and probably will not come off. With my '98 EX, I had to break the bolt, cut the strut off and use a drill press to get the old bolt out. I picked up a new bolt from a local dealership for less than $4 I think. Head to parts store and buy a tube of antiseize and rub it along the shaft of the bolt (the part that lays in the sleeve) before sliding it in and torquing it down and you won't have this problem again. Good luck.
Old Sep 18, 2003 | 06:49 PM
AP1dude's Avatar
AP1dude
JDM WHORE!!!
this is what civics are notorious for that dam bolt.
Old Sep 18, 2003 | 06:57 PM
bobbybosche's Avatar
bobbybosche
I used every method known to man to get this bolt out when I upgraded to my Neuspeed suspension. We even drilled all the way through and it still didn't budge. I had to scrap the whole strut and control arm and buy a control arm from the junk yard! The bolt on the other side was twisted so bad I had to replace it. From the dealer those bolts are $11.00 a piece plus tax! Definitely use antiseize when you can!
Old Sep 18, 2003 | 07:25 PM
SRT_Andy's Avatar
SRT_Andy
Sell your car and buy one that you can take those bolts off of.
Old Sep 18, 2003 | 07:28 PM
dantastic's Avatar
dantastic
cx power!
jeez. good thing i live in cali. i've installed atleast 5 sets of shocks/springs in 3 different cars, and never have i ever had problems with suspension bolts. even on my 93 civic with 126kmi on it
