overheating
Old Apr 10, 2003 | 03:54 PM
derf's Avatar
derf
Spec5
Default overheating
I think some part of my radiator fan is broken cuz my car starts to over heat at a stand still...
can someone tell me where to start lookin? (no manual..)
sounds like a partly stupid question. but i'm lazy
HI EVERYBODY.. i haven't beeen on this for months!
Old Apr 10, 2003 | 04:12 PM
Hondaman's Avatar
Hondaman
Black Pearl
What do you get for gas mileage on average?
Old Apr 10, 2003 | 04:31 PM
toadolson's Avatar
toadolson
The One And Only!!!
Sound like your cooling fan is not working. My fan turns on only at a stand still.
Old Apr 10, 2003 | 07:17 PM
derf's Avatar
derf
Spec5
it aversages around 25 these days.. if i'm lucky.... (my mpg)
i'm most postitive it is my cooling fan.. i think i'll start lookin in the fuse box to see if something is blown first.... could the motor be completely shot?.... i guess i'm just askin for a likely cause
Old Apr 10, 2003 | 07:37 PM
Hondaman's Avatar
Hondaman
Black Pearl
Ahhhhh,
That's what I thought. Try changing your temp sensor. That's what tells the computer how hot the car is and when to turn the fan on and off. It also tells the car when it's warm and when the computer should switch from open loop to closed loop and vise-versa. If it's not working properly, your gas mileage will go to hell and your fan won't come on. I believe it's located in the thermostat housing if I remember correctly.
Good luck.
PS, it won't hurt to check the fuses either.
Old Apr 10, 2003 | 07:48 PM
dantastic's Avatar
dantastic
cx power!
run some wires from the battery to the fan and see if it turns on
Old Apr 10, 2003 | 08:30 PM
derf's Avatar
derf
Spec5
Originally posted by Hondaman
Ahhhhh,
Good luck.
does it come in contact w/ the antifreeze? or is it a sensor that plugs into the housing....
i'll look into the problem tomorrow.. i wouldn't imagine the fan broke.....
Old Apr 10, 2003 | 09:36 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
right near your oil filter, there is a clip that plugs into the back of the block. Make sure that is hooked up. If not, your fan will never come on. But jsut start your car and let it idle for a while in the driveway. ONce it gets up to temp, if the fan doesn't kick on, you'll know what's up.
Old Apr 10, 2003 | 11:19 PM
derf's Avatar
derf
Spec5
sounds good. if i let it sit there long enough, the temperature will go up 4/5 all the way up.... so yea. no fan turn onage
Old Apr 11, 2003 | 04:28 AM
ManTiS's Avatar
ManTiS
NinJA
- Clogged radiator
OR
- Bad Thermoswitch
