overheating
Old Apr 11, 2003 | 08:46 AM
dantastic's Avatar
dantastic
cx power!
Originally posted by Bakeoff
right near your oil filter, there is a clip that plugs into the back of the block. Make sure that is hooked up. If not, your fan will never come on. But jsut start your car and let it idle for a while in the driveway. ONce it gets up to temp, if the fan doesn't kick on, you'll know what's up.
d00d. that's oil pressure. the thermoswitch is on the thermostat housing
Old Apr 11, 2003 | 11:34 AM
Hondaman's Avatar
Hondaman
Black Pearl
Just did some research, it depends on the engine. The DHOC has it by the distributer on the front of the engine and the SOHC 1.6 has it in the stat housing. Hope this helps.
Old Apr 11, 2003 | 02:14 PM
derf's Avatar
derf
Spec5
stat housing.. whats that?
Old Apr 11, 2003 | 02:52 PM
Hondaman's Avatar
Hondaman
Black Pearl
Thermostat housing
Old Apr 13, 2003 | 06:52 PM
derf's Avatar
derf
Spec5
you all are telling me to change the temp sensor.
doesn't that also work the temperature gauge in your cluster? cuz that still works. if I drive it all day, it'll never overheat. It will ONLY over heat when the car isn't in motion. so that led me to conclude that the radiator isn't clogged cuz once air starts to cool the antifreeze, the temp immediately drops. if there are two sensors... the thermoswitch is on the thermostat housing (thermostat was replaced <2 years ago) where is the sensor that tells mr. ecu how hot the car is and in turn controls the temperature gauge?
thanks guys. stupid car.. gotta keep on drivin!
Old Apr 13, 2003 | 07:02 PM
Hondaman's Avatar
Hondaman
Black Pearl
You are correct, there is one "sender" and one "sensor". The "sender" is what makes the needle on the gage move. I believe that is located on the block some where. The "sensor" is located in the thermostat housing. It's the one that talks to the ECM. Make sure the plug is clipped on to the sensor.(that's an easy first check) Sometimes when they change the thermostat, they forget to plug the sensor back in, you have to unplug it to change the thermostat. If that doesn't work, you may want to try replacing the sensor.
BUT!!!
Have you tried checking just the fan? All you have to do is disconnect the fan and hook up a 12v source to it(ie battery in the car) If the fan spins when you hook up power, the fan is good, if not, the motor maybe burned out. That's an easy and free check as well.
Old Apr 13, 2003 | 07:26 PM
derf's Avatar
derf
Spec5
when I changed the thermostat, I didn't have to unhook it. but that was years ago and this happened 2 months ago... but i will do as you suggest.
are those the ONLY causes of a no-turn-on?
Old Apr 13, 2003 | 07:47 PM
Hondaman's Avatar
Hondaman
Black Pearl
Those are the only two that come to mind. Anyone else have an idea? If I were you I would start with the plug and see if the connection is clean and tight, then check the fan with a 12v power source to see if the motor works. If that doesn't work... :dunno: It maybe time to talk to a Honda service tech.
Old Apr 13, 2003 | 08:58 PM
ManTiS's Avatar
ManTiS
NinJA
If you're overheating at idle, then your fan is not turning on or your radiator is fuked. When the car is moving, air goes through the radiator and cools the coolant; therefore, no overheating.
Old Apr 14, 2003 | 01:36 AM
derf's Avatar
derf
Spec5
if the engine cools while moving.. then the radiator is fine.. problem.....
ANYBODY have a site they goto for replacement parts? like the thermoswitch?
