Most Economical swap. Price?
Old Feb 24, 2003 | 02:34 PM
vtec_concept's Avatar
vtec_concept
I would go with the B18B (LS non-vtec motor) and GSR tranny, as well add CTR pistons and a Turbo...
THat would be the most economical swap there
Old Feb 24, 2003 | 02:58 PM
Ronin625's Avatar
Ronin625
is there a site where I can look at SWAPs or something? If i get my civic i want to swap my engine too.
Old Feb 24, 2003 | 03:06 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Why would he add ctr pistons, arent they high comp pistons? If he was going to get pistons he should get some 9:1 aftermarket pistons.
Old Feb 24, 2003 | 03:09 PM
dantastic's Avatar
dantastic
cx power!
http://tech.hybridgarge.com
Old Feb 24, 2003 | 03:19 PM
Kai's Avatar
Kai
Rotorphile.
Originally posted by randomtask77
I got quoted for 795 for the LS motor alone. I didn't get to ask about milage and what not. I just wanted a ball park figure on the motor. Is that a good price?
$795 You can get a B20 longblock for that much, even entire B18A/B swaps! You need to shop around a little more. $550 for the transaxle is obscene.
Old Jul 20, 2003 | 08:07 PM
lkailburn's Avatar
lkailburn
college kid
whats the big hype about throwing in an LS motor. can someone post specs about it. like all stock specs, and then ls with maybe t3 turbo. thanks
Old Jul 20, 2003 | 08:28 PM
Kai's Avatar
Kai
Rotorphile.
(talk about back from the dead, this is five months old...)
There is no hype, the B18A/B is a stronger engine.
90-91 B18A 130hp/121ft-lbs
92-93 B18A 140hp/126ft-lbs
94-01 B18B 138-142hp/126ft-lbs (hp depending on year)
With a turbo, it really depends on what pressure and other mods you run.
Compair that to your stock engine and you will notice the B18A/B is by far stronger.
Old Jul 20, 2003 | 10:56 PM
SSCivic's Avatar
SSCivic
Swolen Member
He could run high compression and low boost, but if he wants to boost a lot do low 9:1 compression pistons and built the block. I been doin some research :-)
Old Jul 20, 2003 | 11:03 PM
ragerized's Avatar
ragerized
dc4 ownerages
what about a b20? its 2 liters and ive heard with boost they can be amazing. it has a lot a torque too. its not too harsh on the wallet. what are the cons of this swap? all ive heard is that the sleaves arent very strong...i dunno.
Old Jul 21, 2003 | 01:15 AM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
The sleeves arent a problem under 15 psi. Seems like a pretty good engine and more displacement should make more power.
