my window wont close
Old Feb 17, 2003 | 11:07 AM
  #31
Max Power's Avatar
Max Power
Buff Member
Originally posted by Jkan2001
okay i just noticed you asked how to take the door panel off and i've done it like 6 times in the last month so i think i'm qualified to explain.
First you have to pull the door handle and there's a phillips screw behind it, take it out. Then there are a total of 6 screws behind your front 6.5" speaker grill. You have to pop the grill off using a flathead (there's a little notch near the bottom) take the speaker out which is held in by 3 screws.
Next there are 3 holes around the speaker each has a phillips screw, take those 3 out. In the side of the door where you hold when you open/close the door there's a little screw inside the plastic tray, you have to take that one out to.
Recap...so far you've taken out 1 door handle (the one you pull to actually open the door) screw, 1 door handle screw (in the plastic tray where you push/pull the door) 3 from the speaker, 3 more around the speaker.
Next you have to take a flathead and take your tweeter out of the corner, it just wedges in there with a little clip. You'll take the plastic piece that goes around your door handle that opens and slide it all the way back and twist it so it fits over the door handle and you can take it off. After you get this panel loose you have to unclip the power window harness near the front of it.
Then you can stick a flathead near the back of the door skin and pop the clips open and just pull it up and off the door. Be careful though cause there is another bigger clip that goes into a harness right under your power window buttons, you have to disconnect it.
That's pretty much it, just put everything back the same way and you should be set....good luck.
EDIT: The screw you have to take out of the 2nd door handle is actually the same plastic piece as the plastic power window button console. If you look down near the back where there's a hole to for you to grip onto there's a small phillips in there.
Also when you put the door on you have to put the lip of the door skin OVER the metal lip of the actual door itself and then push down or else you'll have a huge gap and nothing will line up.
Feel free to IM me at jkan2001 if you run into any other problems.
ahh i took off the door panel, couldnt figure out or get to the window part, and now i cant figure out how to put this damn door panel back on
Old Feb 17, 2003 | 11:31 AM
  #32
Jkan2001's Avatar
Jkan2001
S2000 Pilot
just IM me at jkan2001 and i'll see if i can help you figure it out.
Old Feb 17, 2003 | 03:13 PM
  #33
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Originally posted by asiandoood
my window is slow cause my arm is slow
Old Feb 17, 2003 | 06:41 PM
  #34
Max Power's Avatar
Max Power
Buff Member
ahh i eventually figured it out. just frustrating . .. you know how you said pop the clips and lift up. i should have reversed the directions by LOWERING DOWN and poping in h:
thanks man they were some mighty fine directions i just didnt read them thouroughly enough
o well at least i know how my door panels are put on now
Old Feb 17, 2003 | 08:11 PM
  #35
Jkan2001's Avatar
Jkan2001
S2000 Pilot
np...glad you figured it out, always glad to help a fellow HANer out :thumbup:
Old Feb 17, 2003 | 11:08 PM
  #36
canada's Avatar
canada
514.315.407.405
I had a pic walkthrough for that before...
(should be in the archives )
(yea right )
