Noise when turing - save me from going to the dealer please!
They take the whole axle, not the boot. The refurbish and resell them.
I wouldn't do that. I have heard that they just take those axles and put a new boot on them without inspecting them. I would rather buy a new OE part.
Well I got the lower driverside ball joint replaced.
It cost $180 and that sucked since the part was only $41.
They also said I should replace the front pass. lower ball joint, pass. tie-rod, and both cv-boots before they tear. parts and labor was $650. I told him to forget it and ill try to tackle them myself.
Parts for all that was about $125.
Never done ball joint, tie-rod or replaced cv boots.
how hard are these. The car car sit for a while if need be. Its my Winter Beater.
Im not about to drop $650
really not that hard at all. CV shafts are 15 min job with the right tools. There is an excellent write up on here, i believe in the sticky about doin the CV's if you need a referance.
As far as the ball joints go, use the helms manual as a referance. More time consuming that anything.
You will probably need some power tools to complete the job effectively, unless you can be very patient and persistent. Other than that, its no problem. Just get a manual and you're good to go.
I changed out an entire half shaft in a meijer parking lot with minimal hand tools and a floor jack in like 30 minutes. It seriously isnt that hard. The biggest bitch will be the axle nut. After that its all gravy.
hell yea.. i pulled off the same deal after bein a show-off puttin my car sideways doin a burn out in a taco bell parking lot i snapped one in half. Had to change it in the parking lot. Everyone was laughin till i pulled out my tools & my spare axle from my trunk & showed them what real car builders can pull off on their own!
