Ask simple and basic questions part duex...
Old May 15, 2003 | 10:06 AM
  #151
Toms Civic EX's Avatar
Toms Civic EX
I need some help, I need to know the size of the center dash bulbs, the ones that light up when you turn on your head lights. I went over to honda and they said it was a 194 size, I then went over to pick some up at advanced auto parts it the 194s are like 3 times bigger than what I need, but I saw some that looked about right (size 37).. the 37s fit but it was a tight squeeze, and they look like ass because it lights up kinda yellow and makes the car look really old, So does anyone know the right size? or should i just paint them 37s blue?
Old May 15, 2003 | 11:25 AM
  #152
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Originally posted by jngledave
There is something that looks like a sensor in my intake. When I put my new intake I moved the sensor, but it doesn't fit right. What is this sensor and is it neccessary in an aftermarket intake?
Yes it's necessary. It's a air temperature (if I remember right) sensor. Detects the air coming into the engine so the engine can regulate fuel to the engine.
Autocross Help Page
Old May 15, 2003 | 07:53 PM
  #153
mattatuncg's Avatar
mattatuncg
My INT (setting before LO) setting on my winshield washer's is not working. I've check the fuses under the steering wheel and I have no burned fuses. Would that fuse be located in the fuse box under the hood? Thanks.
Old May 16, 2003 | 08:31 AM
  #154
CivicSiRacer
Under the steering column on the driver's side.
Autocross Help Page
Old May 16, 2003 | 06:51 PM
  #155
Motohip's Avatar
Motohip
Originally posted by inspyral
2dr/hatch 5th gen front bumpers should be interchangable. The hatch sideskirts may be shorter though. Incidentally, 6th gen sideskirts can be adapted to 5th gens, and they look pretty clean. All 6th gen sideskirts are the same length.
Do you know if 6th gen sides will fit a del Slo?
Old May 20, 2003 | 07:42 AM
  #156
bLaCkLiNgEriE's Avatar
bLaCkLiNgEriE
Blah blah blah.
More questions!
*What is the difference between a DOHC and a SOHC?
*Are '99 EX's all V-Tec's?
*What does "shaving" mean when it's referring to cars?
*When I step on the brake pedal , my steering wheel shakes; why does it do this?
Old May 20, 2003 | 06:36 PM
  #157
Motohip's Avatar
Motohip
Originally posted by bLaCkLiNgEriE
More questions!
1. Rever to THIS thread. Lots of good information.
2. All 92-95 EX and SI's have 1.6 liter SOHC VTEC engines. All 96-00 EX's have 1.6 liter SOHC VTEC engines. 99-00 SI's have 1.6 liter DOHC engines. 01 + EX's have 1.7 liter SOHC engines.
3. Shaving means to do away with the seams or gaps of a car. Like the gap that sepparates the bumper from the fender to look like one piece. Or to remove a part of the car such as: antennae, door handles, emblems, etc...
4. Probably your rotors need to be resurfaced or they may be really warped and need replacement.
Old Jun 1, 2003 | 09:54 PM
  #158
EJcivic02's Avatar
EJcivic02
I talk Before I think
Is the 92-95 HB rear the same as the 92-95 Coupe rear? Im asking because i might buy a rear lip for a HB, but dont know if they have the same rear bumper or if it will fit on a Coupe. Anyone help? Thanks
Old Jun 2, 2003 | 06:40 PM
  #159
CivicSiRacer
Nope not the same.
Autocross Help Page
Old Jun 2, 2003 | 11:51 PM
  #160
EJcivic02's Avatar
EJcivic02
Originally posted by CivicSiRacer
Nope not the same.
Thanks
