Redline Water Wetter
Old Oct 28, 2002 | 09:49 AM
wilsel's Avatar
wilsel
Nope! I know when I changed my thermostat last year I did it the way CIVICSIRACER mentioned. After a week or so my car would still over heat only every once in a while. I had to bleed it using the valve several times before it permanently stopped. I don't see why they'd have the the bleeder valve if the resevoir performed the same purpose.
Old Oct 28, 2002 | 09:53 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
i wonder why?
Old Oct 28, 2002 | 01:37 PM
ManTiS's Avatar
ManTiS
NinJA
There is also a bleed off valve right where the upper radiator hose comes out of the engine.
What's this bleed valve look like? Is that by the valve cover?
Old Oct 28, 2002 | 08:10 PM
Scott T's Avatar
Scott T
Originally posted by fujiwara takumi
i wonder why?
The pressure cap only bleeds off excess pressure, it doesn't necessarily allow air to escape. The bleed valve will be located at the highest point of the colling system - an air bubble will tend to settle there when you shut the car off (of course let it cool before opening).
Old Oct 29, 2002 | 05:44 AM
wilsel's Avatar
wilsel
Right where the upper rad. hose comes out from the engine. It should be a 10mm or 12 mm bolt with a hollow tip at the top of it.
Thats the best I can explain it. Just loosen it until you see bubbles coming out. Tighten it back up after no more bubbles are coming from the tip. Should be a small steady stream of coolant.
Old Oct 29, 2002 | 06:19 AM
Fujiwara Takumi
It's my first day.
why dont you try reading the thread before you respond next time :slap:
Old Oct 29, 2002 | 07:15 AM
Scott T's Avatar
Scott T
I DID read the thread - you asked why the reservoir doesn't automatically bleed off air bubbles, I explained why it does not. It's not my fault you don't understand how the cooling system works.
Old Oct 29, 2002 | 07:44 AM
Fujiwara Takumi
It's my first day.
thats not what you explained. Youre talking about the pressure cap, the cap on the resevoir is not pressurized.
Old Oct 29, 2002 | 08:15 AM
Scott T's Avatar
Scott T
The overflow cap on the RADIATOR is pressurized (spring-loaded valve), this bleeds off excess coolant through the overflow tube to the reservoir when pressure gets too high (it releases at 12-14 PSI on most cars). It will not selectively let air out, unless the air bubble just happens to be sitting next to the pressure cap when pressure gets high. This is unlikely, since the air bubble will circulate with the coolant as long as the water pump is running. The bubble will rise to the highest point when the car is off, which is where the coolant burp valve should be located.
Old Oct 29, 2002 | 08:29 AM
Fujiwara Takumi
It's my first day.
im aware of all that, i just like splitting hairs. sorry.
