Redline Water Wetter
Old Oct 28, 2002 | 07:44 AM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Bleed the coolant?
Anyhow after putting that wetter stuff in there I noticed it takes longer for my car to heat up so maybe it does work.
Old Oct 28, 2002 | 07:45 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Originally posted by FourthGenHatch
Bleed the coolant?
its good ****, we use it for water-cooled computer applicatios. you look at an average core temp drop of 1-2c, which is pretty remarkable.
Old Oct 28, 2002 | 08:04 AM
ManTiS's Avatar
ManTiS
NinJA
Bleed the coolant?
I've had water wetter+water for a long time. I know it 'works.'
Do people not understand OVERHEATING? I am overheating, as in the needle goes to the big 'H.'
I'm going to take out the thermostat and see what's up.
Old Oct 28, 2002 | 08:07 AM
Fujiwara Takumi
It's my first day.
what about a plug in your hoses? is that water pump working? the cold could be gumming up your bearings, it may not be up to snuff.
Old Oct 28, 2002 | 08:15 AM
ManTiS's Avatar
ManTiS
NinJA
I want to check other stuff first. I've been doing some research. I hope it's not my water pump or headgasket. I hope it's simple like a radiator cap.
I am almost certain that I have a leak and/or sticking thermostat. I was overheating (again) on my way to school. I felt both upper and lower radiator hoses. The upper was obviously hot but the lower was cool to the touch.
Old Oct 28, 2002 | 08:22 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
After using Redline WW my engine temp dropped about 30 degrees.
But someone mentioned bleeding the system. When your car is cool open the radiator cap and turn the car on and let it run for about 15 minutes. Bubbles will mess up the cooling system.
Autocross Help Page
Old Oct 28, 2002 | 08:25 AM
Fujiwara Takumi
It's my first day.
and thats the return line correct? or the feed line?
Old Oct 28, 2002 | 08:27 AM
ManTiS's Avatar
ManTiS
NinJA
Yea, I gotta do that when I get home. Not home right now. Water wetter was fine during summer, but I think that it got cold and my not having antifreeze fugged everything up.
Later, off to the Honda dealership I go to pick up: thermostat, radiator cap, coolant.
Wish me luck.
Old Oct 28, 2002 | 09:02 AM
wilsel's Avatar
wilsel
There is also a bleed off valve right where the upper radiator hose comes out of the engine.
Old Oct 28, 2002 | 09:03 AM
Fujiwara Takumi
It's my first day.
doesnt the resevoir perform this task automatically?
