High Mileage Oil???
Old Jun 16, 2004 | 06:26 PM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by zyzyx6969
15,000 miles
For a modern engine, that actually isn't as bad as it sounds. Piston engines, with a decent oil, can go 7500-10k before a change. You can usually get away with 15k with a filter change and regular topping up of the oil level.
Old Jun 16, 2004 | 07:29 PM
BassmintPimpin's Avatar
BassmintPimpin
EBP'n It!
In my old D-Series, I never changed the oil. Probably had 30,000 miles with the same oil. But, I had a DOHC sitting in the garage so I didnt care!
Old Jun 16, 2004 | 08:32 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
With pure synthetic oils (most off the shelf oils are not pure synthetics) you can go about 30,000 miles between changes - you just have to make sure you change the filter every 3000-5000 miles.
Synthetic oils do not break down as quickly as conventional oils do, so they last longer.
Autocross Help Page
Old Jun 16, 2004 | 11:35 PM
pez's Avatar
pez
is mobil 1 synthetic pure synthetic? if not how many miles should i wait before changing?
Old Jun 17, 2004 | 10:43 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
you can easily go to 5000 miles with synthetic.
I was in walmart buying some Mobile 1 5w_30 to change out my gearbox fluid.
Some old guy (60-70) behind he starts up a conversation
"Mobile 1 - best oil out there. I used to work for mobile 1. I keep mobile 1 in my truck. I never change the oil in my truck. Same oil for X number of years. I just change the oil filter regularly, and add more oil as needed when doing that. The stuff never breaks down"
Take it for what its worth.
shoot, if you're mainly highway miles, even regular oil is good for 5000+
synthetic can last a while.
Old Jun 17, 2004 | 11:28 AM
CivicSiRacer
Mobil 1 used to be labelled SYNTHETIC but now it's labelled TRI-SYNTHETIC. So I don't know what that means.
My Royal Purple or Amsoil is about $8-10/quart compared to Mobil 1 which is about $4
Autocross Help Page
Old Jun 19, 2004 | 12:08 PM
nate886's Avatar
nate886
Green: The genius color.
...and thats why you have to keep it in your engine so long! :db:
P.S. - Everyone should check out CivicSiRacer's other post (HERE) from waaay back. There's some good stuff in there. A little off topic - more related to synthetics than high mileage oil, but still pertinent. h:
Old Jun 19, 2004 | 05:49 PM
CivicSiRacer
Well figure you pay twice as much, but you can leave it in your engine almost 3-4x longer. I'm about to send in a pint of my oil to be tested in a few days. The oil has been in there for a long time, but of course with frequent oil filter changes.
Autocross Help Page
Old Jun 19, 2004 | 06:16 PM
Bregar_Highside's Avatar
Bregar_Highside
Try these 2 sites. More oil info then you'll ever want.
http://neptune.spacebears.com/cars/s.../oil-life.html
http://www.bobistheoilguy.com
