Wheel hub, lug nut question for anyone?
Lug nuts can strip or seize on the stud if you don't properly clean them when installing/removing them.
I always wipe them with a towel and put some anti-seize on them. Remember to only torque them to 80ft/lbs. If you go by just arm strength most people OVERTIGHTEN causing the threads to strip.
In my experience it is never the lug nut manufacturer's fault always the installer/user.
And yes I've had my fair share of sheared lug nuts/studs. Since I change my wheels/tires about 40 times a year when I autocross.
Autocross Help Page
Autocross Help Page
but do you apply antiseize on the whole stud itself or on the lugnut tip only where the lugnut touches the wheel?
If you put it on the stud you will get antiseize on your wheel. I put a dab on the inside of the lug before installing. Ever since 2002 when I started doing it I've never stripped or had problems with my lugs/studs. Before that I must have stripped or seized a lug nut/stud about 3-4 times a year.
Autocross Help Page
Autocross Help Page
i also factor in what color your rims are if there black slips i would get sum red tuner lugs
lower price
expensive
lower price
expensive
There are 2 different lugs for Hondas.
Acorn (conical) shaped and ball (spherical) shaped. Just make sure you look at the lug seats before buying.
Autocross Help Page
Autocross Help Page
