Can I put a P28 ECU to a OBDII engine?
Old Mar 16, 2008 | 06:40 AM
evolutionviii5m's Avatar
evolutionviii5m
Default Can I put a P28 ECU to a OBDII engine?
OK I have a 1997 honda civic and my question is can I install a P28 ECU into my existing wiring harness? or do I have to get the wiring harness for the P28? because I do have the P2e ECU and that one is OBDII and the P28 is a OBDI for civics from 1992thru 1995 I believe well thank's
Old Mar 16, 2008 | 07:26 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The plugs are different, so you'll need an OBD2a to OBD1 harness.
