B16 No Boost!
Old Feb 3, 2007 | 06:03 AM
  #31
delsol161's Avatar
delsol161
out of curiosity... did "safety switch" refer to a boost controller? maybe a wastegate?
Old Feb 4, 2007 | 04:30 PM
  #32
Running925's Avatar
Running925
Your Powder Coater
Originally Posted by JoePoonani
Sorry to jack, but would a stock PCV system suffice with a low boost and conservative tune application?
Any time there is going to be positive pressure involved, there should be some way to vent the postive crank case pressure in the works. ANY positive pressure applied to the bottom of the rings is going to net you some type of problem. It's just a ticking time bomb man.. read up on it a little bit.. u'll see how important it really is.
Old Feb 4, 2007 | 04:52 PM
  #33
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by DaGip
yeah I'm sure he will just use a filter on the valve cover. and also Schmoo the Greddy oil catch can does it offer any benefits to N/A cars besides cathing blow-off gases, if not is it OK if i still buy one just as an accessory item
It doesn't catch blow off gases, it catches oil and gasoline vapors created in the crankcase. The Greddy can would only be suitable for an N/A application since it isn't an open breather can, so the gases have no where to go when the PCV is shut under boost pressure. You would have to add an open breather to it in order to use it effectively on a forced induction setup.
You can buy one, but it won't do much of anything until you are running a more aggressive engine setup. Personally, money is better spent elsewhere.
