B16 No Boost!
Old Feb 1, 2007 | 04:03 AM
Omniscient's Avatar
Omniscient
warm butter on toast
PSI won't kill a motor. Too much ower and detonation will.
Old Feb 1, 2007 | 05:31 AM
Running925's Avatar
Running925
Your Powder Coater
Originally Posted by Omniscient
Just make sure he changes his stock PCV system...
should have been a given
blown rings/lands wned:
Old Feb 1, 2007 | 08:05 AM
DaGip's Avatar
DaGip
4N2Ner
ill make sure to let him know, thanks.
Old Feb 2, 2007 | 12:40 PM
project_hatch's Avatar
project_hatch
Power by Uncle Ben's Rice
The only thing i've ever heard about B16's and Boost is because the B16 has a higher compression ratio that it's not made for high boost but other then that I don't know shit about them
Old Feb 2, 2007 | 04:07 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Sorry to jack, but would a stock PCV system suffice with a low boost and conservative tune application?
Old Feb 2, 2007 | 04:25 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Define low boost.
Anytime the PCV valve sees positive pressure, it will shut and trap the crankcase pressure forcing it against the rings and possibly break ringlands. A breather filter on the valve cover should be sufficient for low boost. Your tune has no affect on this.
Old Feb 2, 2007 | 04:39 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Originally Posted by Däs Schmoo
Define low boost.
I'm talking around 8psi on a T25. So how would I eliminate the PCV system and just use the breather?
Old Feb 2, 2007 | 05:23 PM
Snoopy's Avatar
Snoopy
been there done that
the ideal way to do it is run a catch can
Old Feb 3, 2007 | 01:15 AM
Omniscient's Avatar
Omniscient
Breather filter on the valve cover, two hoses coming off gutted PCV box.h:
That's my catch can.
Old Feb 3, 2007 | 04:59 AM
DaGip's Avatar
DaGip
4N2Ner
yeah I'm sure he will just use a filter on the valve cover. and also Schmoo the Greddy oil catch can does it offer any benefits to N/A cars besides cathing blow-off gases, if not is it OK if i still buy one just as an accessory item
