Transmission Noise
Old Oct 16, 2006 | 01:42 PM
Line7's Avatar
Line7
Platinum Member
Default Transmission Noise
I have a D16z6 manual transmission. I was driving on the highway yestreday and I guess I didn't downshift very smoothly and now I have this bad noise coming from the transmission. It sounds like a half GRINDING, half metal-RUBBING noise. Sounds like some bearing or something is loose and rolling around or something. I hear it mostly when I am in Low or second gear and mostly as the RPM's are dropping or when I keep it at like 2000 rpms. Sometimes I even hear it when I'm idling in neutral. Please help. Thanks guys.
Old Oct 16, 2006 | 02:53 PM
t3t4delsol's Avatar
t3t4delsol
probly broke a tooth off a gear and its rattling arround, not good, becuase if that tooth wedges itself in a gear kiss the tranny good bye
Are you sure its comming from the tranny?
And not your exhaust
Old Oct 16, 2006 | 02:54 PM
t3t4delsol's Avatar
t3t4delsol
also could be sincros
Old Oct 16, 2006 | 03:02 PM
Running925's Avatar
Running925
Your Powder Coater
tear it down & look!
Old Oct 16, 2006 | 08:17 PM
Line7's Avatar
Line7
Platinum Member
Yeah I guess I should. Thanks. Anyways it's more like a rattling noise like a tin can is just bouncing around in there. It's definitely not the exhaust. Thanks
Any more ideas??
Old Oct 17, 2006 | 03:21 AM
m735is's Avatar
m735is
I've had the same noise for MANY miles. I thought it was the throw out bearing, nope. The I thought it could be the pilot bearing, nope. Short of tearing it down and completely breaking it, I live with it. The last time I had the tranny out (for the pilot and rear main), it sounded good for a few days with fresh oil in it, now it does it occassionly. Usually when cold and sometimes when turning left. Not usually when warmed up and going straight or right. Since I have another tranny I figured I'd wait for it to finally blow, but it has been a year or two, which means somewhere around 60,000 miles.
Both times I drained the tranny oil, there was no eveidence of color change or metal flakes that I could see.
Old Oct 17, 2006 | 04:05 AM
civicburner's Avatar
civicburner
I'm no expert when it comes to transmissions, but I had this problem about two years ago. I took it to the shop and they told me that it was the case bearing. They fixed it and my tranny has been noise free since. There were other problems too, but they weren't causing the noise.
Old Oct 17, 2006 | 03:06 PM
Line7's Avatar
Line7
Platinum Member
thanks guys. i'll tear it down as soon as i get the chance.
Old Oct 28, 2006 | 07:40 PM
eg6lover's Avatar
eg6lover
does anybody know where i can take my tranny to get it serviced? it's f-d up. can't go into reverse, 3 gear doesn't go in n grinds. basicaly no tranny in the car. any shops specialize on b16a2(LSD)tranny's and that will not rip me off. i live in Burbank, CA.
Thanks
Old Oct 30, 2006 | 01:26 PM
Ef6-97's Avatar
Ef6-97
STEVE-0
I know my d serise trans used to sing when it was cold.. it sounded like a race trans untill it warmed up. I put some synthetic motor oil real thin in my gsr trans.. i dont remember exsacly but all the swap forums reccomended it but it works awsome in the cold and the heat.
