got a serious question
Old Sep 28, 2002 | 08:50 PM
justasquirrel's Avatar
justasquirrel
tryin' to get a nut
okay, okay, no flaming, guys! i don't need a bunch of CRAP to sift through to find the answers to my questions.
well, speedracer, i actually have plans to run a t04e turbo. i read in an article from sport compact car that it would combine well with my engine to make 300-400hp. i have the article somewhere (can't find it right now), and it says that this would be a good turbo for maximum street performance (sorta a medium between all-out, big lag race only setup and fast-spool, lower boost autocross setup). i don't know the intake and exhaust trim sizes off hand, but these are the guidelines i'm going to use.
so, i guess judging from your comment, i will prob have to run between 18-22 psi to get my desired hp??? also, i guess it would be helpful to mention that i will be running a full 3" exhaust system from the exhaust outlet of the turbo back.
Old Sep 28, 2002 | 09:01 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
You really dont need to run that much boost. Its all in the tuning. Guy i know just got his hondata 2b tuned on his stock b18b and is making 274 whp @ 12 psi that @ like 5400 rpms. The more boost the more likely your going to hurt the engine.
Old Sep 28, 2002 | 09:07 PM
justasquirrel
tryin' to get a nut
well, i don't think i'm gonna get a hondata system just yet. i'm going to just try to get the motor to run what it can off the "stock" ecu and basic setup. i plan to get something like the hondata later on down the road. hell, i might even eventually try out this water injection thing before it's all said and done. lol
Old Sep 29, 2002 | 01:26 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Originally posted by crucial Si
you are controdicting yourself:fawk:
i'd gladly give up my d16y8 for a nonvtec LS or B20 motor...as long as i had turbo still so :fawk:
too bad you're just stuck with sohc vtec bwahahah j/k :thumbup:
Old Sep 29, 2002 | 01:28 PM
crucial Si's Avatar
crucial Si
Banned
since my exterior is gonna be done really soon, all i need left to get are oem fogs, and c/f spoiler, im gonna work more on my suspension and engine,aahhhhemmm b16 boosted
Old Sep 29, 2002 | 01:31 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
woot for OEM fogs...i think im gonna get me a set too when i pull off my front bumper to do the FMIC. I guess i'm mostly done with suspension except maybe some AGX and a rear sway bar...and why would you work more on your engine and then say you are gonna boost a b16. I'm going to skip the whole waste of time 1.6L route after my pos d16 dies and go straight b20.
Old Sep 29, 2002 | 02:52 PM
crucial Si's Avatar
crucial Si
Banned
the b16 is more reliable...and thats what i need.
Old Sep 29, 2002 | 04:04 PM
justasquirrel
tryin' to get a nut
why don't you guys use the "private message" function here. you are getting waaaaayyyyy off topic.
thanx
Old Sep 29, 2002 | 04:05 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
how is it more reliable...it has higher compression, and you're trying to squeeze more HP out of lower displacement.
Old Sep 29, 2002 | 04:07 PM
crucial Si's Avatar
crucial Si
Banned
max boost is gonna be10 maybe 12 lbs at the track..other than that it will be at 6lbs...and im gonna lower the compression a little bit also
