got a serious question
Old Oct 1, 2002 | 02:23 AM
  #31
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
I believe it has a .60 a/r. But it has a big exhaust turbine, creating lag. The t3/t04's come in a .50, .60, and the big poppa, .70 I'll have to get out my turbo sheet and double check about that t04e.
Old Oct 1, 2002 | 03:33 PM
  #32
justasquirrel's Avatar
justasquirrel
tryin' to get a nut
okay, i got the info today:
scc says that for max street performance in an 1800cc to 2200cc situation you should use:
compressor trim and housing a/r: t04e, 50 trim 0.50 housing
turbine: t31, 76 trim or t350, 76 trim
exhaust housing a/r: t3: 0.63-0.82
strong boost onset: 3500 to 4500 rpm
approximate power potential: 300-420 hp
sounds really close to what you have been telling me. what do you think?
edit: i don't really know if they intend these combinations for a stock, high compression motor, though. i wonder what differences would be present in a 9-1 compression engine as far as lag, onset, and max pressure are concerned...
Old Oct 2, 2002 | 02:05 AM
  #33
SpeedRacerEX-R
No stock B/D bottom end will handle 300 hp. You'll have to build it. I'd go with a 9:1 cr. Or maybe a little higher if you're going to have a bad ass standalone system and some wicked tuning. But 9:1 is pretty safe.
Old Oct 2, 2002 | 07:18 PM
  #34
justasquirrel
tryin' to get a nut
gracias!
Old Oct 2, 2002 | 08:21 PM
  #35
HappySnatch's Avatar
HappySnatch
OG
Originally posted by Jkan2001
who needs vtec when you have BOOOOOOOOOOOOOOOOOOOST
you make it sound like a D16 with boost is the greatest thing since sliced bread
Old Oct 3, 2002 | 03:02 PM
  #36
justasquirrel
tryin' to get a nut
it isn't?!?!
